06+ headlight internals in 03 housings(Can it be done?)
Old Jul 22, 2012 | 08:33 AM
NissanZcrazy's Avatar
NissanZcrazy
Default 06+ headlight internals in 03 housings(Can it be done?)
Hey,
I recently bought a set of 06+ headlights with some broken tabs and a scratched d/s lense.
I was wondering if any of you guys have tried or know if you can put the internals inside of the 03 housings successfully.
Thank you in advance
Old Jul 22, 2012 | 08:56 AM
oscatipo's Avatar
oscatipo
No, it cannot. I tried it with some scrap housings and center section of the plastic housing where the lens is mounted is completely different.
Old Jul 22, 2012 | 11:41 AM
bmccann101's Avatar
bmccann101
youre not asking the question clearly.. what is your final intention.. to use your 03 "housings" so that you can have good tabs and lenses?
First the tabs by hand, they do very little structurally.. if you can cut off the tabs from your other lights and swap them over w jb weld or a steel l bracket, they will be good to go.
Also, the lenses from any 03 headlight WILL fit 06 chrome internals as well as fit ON your 06 headlight bodies.. i ahve a thread explaing it all in detail.
Basically, if the only reason you feel you want to NOT use your 06 guts and backside is that the tabs are broken, like i said, that can easily be fixed.
Again, the 03 lenses WILL fit perfectly and the innards WILL screw into the lens perfectly as well.. You just cant use the 03 black housing etc to mount that projector into etc.
Old Jul 22, 2012 | 01:03 PM
bbs350z's Avatar
bbs350z
^listen to the man, he speaks knowledge
Old Jul 22, 2012 | 07:58 PM
INGSZ33's Avatar
INGSZ33
If you part the headlights let me know. I need some 06+ internals.
Old Jul 23, 2012 | 02:54 AM
bbs350z's Avatar
bbs350z
what parts do you need? i got some stuff
Old Jul 23, 2012 | 04:25 AM
NissanZcrazy
I want to put the 06 internals in the 03 housings so I have all of the tabs present.And I need a good lense d/s.Basically take everything but the housing and lense and put it inside an 03+ housing
If anyone has good 06+ housings or lenses please lmk.EVEN if the very top tab is broken I may wan it.
Thanks guys
Justin100
Nov 25, 2021 06:26 AM
Uriyo_
Sep 8, 2021 08:46 AM
Dsowe
Feb 17, 2021 10:38 AM
JGee450
Sep 30, 2015 04:32 AM
