Rear wiper delete mod completed
Old Aug 1, 2012 | 09:10 AM
AGtheking's Avatar
AGtheking
Default Rear wiper delete mod completed
Just had my buddy finish the rear wiper delete this morning.
Looks perfect to me.
If anyone is looking to do this, it is fairly simple, cheap, and quick.
- 1 inch metal hole plug (ACE hardware stores carry them)
- silicone to make the hole water-tight
The 1 inch plug is a little too big to fit in the wiper hole, so you will have to sand the hole down a bit for a snug fit. Then apply the silicone to both the outside and inside of the hole.
The other option is using a sink stopper and there are several other threads that show all of the steps for both options.
There is also a guy who makes the kits with the OEM color-matched plug for $35 at rearwiperdelete.com/products. I didn't know how long it would take to ship and the metal plugs only cost a dollar each, so I figured that the DIY method was better for me.
Overall, I am really happy with the cleaner look.
Old Aug 1, 2012 | 09:23 AM
sry110's Avatar
sry110
May I suggest either color matching it, or blacking it out to match the trim around the rear window? At any rate, props for DIY.
Old Aug 1, 2012 | 09:24 AM
Bmurray350z's Avatar
Bmurray350z
+1 on color-matching it. then it will look perfect
Old Aug 1, 2012 | 09:32 AM
Duckeee's Avatar
Duckeee
i use my wipers.
Old Aug 1, 2012 | 09:37 AM
Waiz's Avatar
Waiz
You need to paint that with something, black paint even but silver is too noticeable
Old Aug 1, 2012 | 10:03 AM
Ronin82's Avatar
Ronin82
Originally Posted by Duckeee
i use my wipers.
.....Really???? (Not sarcastic)
OEM paint or aftermarket? I never use mine and have thought about doing the delete, on the other hand i didnt want to take away from the OEM look of the car that weren't rims
Old Aug 1, 2012 | 10:10 AM
Duckeee's Avatar
Duckeee
yeah i use mine from time to time to rid condensation in the morning, or for parking when it's raining. i live in the northwest so you know it rains a lot.
that and i do not have a garage..
at any rate, im sure you can get touch up paint and do it yourself. its a fairly small piece. or have a shop paint it
Old Aug 1, 2012 | 10:20 AM
terrasmak's Avatar
I used the sink stopper for mine and a freinds. I did mine a couple years ago, no regrets. I did my friends last night, along with a gut of the hatch.
Old Aug 1, 2012 | 10:37 AM
cgkp0925's Avatar
cgkp0925
Yes, match the plug to the paint and it will look 100X better.
Also, take out the squirt nozzle and it will complete the look.
Old Aug 1, 2012 | 12:19 PM
TPete19's Avatar
TPete19
i use my wipers.
Use mine as well. Damn the Pacific North West!
Old Aug 1, 2012 | 03:34 PM
AGtheking's Avatar
AGtheking
"Yes, match the plug to the paint and it will look 100X better.
Also, take out the squirt nozzle and it will complete the look."
Agree with all of you guys about the color matching and how it would look a bit better, but I like that little bit of silver in there. Otherwise, I would definitely go with that daytona blue or black.
Is the removal of that little spray nozzle easy to do? I didn't look into it yet.
Old Aug 1, 2012 | 03:37 PM
JCITY's Avatar
JCITY
First of all,I use my rear wiper.
Secondly,you must not be very particular about how your car looks.
To have this silver half dollar size plug on your rear deck left unfinished
really looks bad.I bet people will think its a coin or something
and try to remove it.At least get some touch up in your color code and paint that
sucker.Looks as thought this may be your first attempt at this type of thing.
At least a E for effort.
(ZzzzzZ)'s Avatar
(ZzzzzZ)
plz paint match
Old Aug 1, 2012 | 03:53 PM
cgkp0925's Avatar
cgkp0925
For the most part yes.
https://my350z.com/forum/body-interi...e-removal.html
Old Aug 1, 2012 | 04:05 PM
mr. sparco's Avatar
mr. sparco
You enlarged the hole by sanding it? IIRC there are a few DIY on here with better fitting plugs.
Old Aug 1, 2012 | 04:55 PM
AGtheking's Avatar
AGtheking
This was more of a post to show others that is was an easy modification to do. I wasn't making an attempt to tell others to do the same thing and to also keep the silver paint on the plug. If I like the look, that is all that matters to me.
Thanks for the link to that thread cgkp0925
Old Aug 1, 2012 | 08:46 PM
Lee R's Avatar
Lee R
To me it is pointless unless you shave it clean. I thought that was the whole basis for this mod in the first place.....a smooth clean look.
Old Aug 1, 2012 | 10:20 PM
bluelineshooter's Avatar
bluelineshooter
I used the plastic plug for weight reduction!
Old Aug 2, 2012 | 03:09 AM
taywan's Avatar
taywan
Paint it mos def. I wrapped mine carbon fiber.
I actually wanted to shave the hole completely but a lot of shops dont want to touch it bc so close to window.
Old Aug 2, 2012 | 03:13 AM
AGtheking's Avatar
AGtheking
"To me it is pointless unless you shave it clean. I thought that was the whole basis for this mod in the first place.....a smooth clean look."
Lee R, do a lot of the other modifications shave down the top of the plug/stopper, so that the piece is very flat and almost on the same plane as the exterior surface around the hole? What type of tool should I use to shave that down? Thanks
"I used the plastic plug for weight reduction! "
Haha, I have only been reading into the forums on here for a few weeks, but I know that there are a lot of members who are very conscious of that tiny weight difference between the two materials. That's awesome for you then. My Smurfette is going to be a little heavyset
