I Cant For The Life Of Me Take My Shift Knob Off! Help Anyone?
Old Aug 4, 2012 | 02:21 AM
kennyy's Avatar
kennyy
Default I Cant For The Life Of Me Take My Shift **** Off! Help Anyone?
hey guys, ive been trying every way on this forum to take the shift **** out but i cant, is there any other tricks or certain ways to take it out?
Old Aug 4, 2012 | 02:48 AM
KingBaby's Avatar
KingBaby
Hardest Setting
Should be easy as lefty loosey...however if you're not the first owner a previous owner might have glued it down, if you can't break it free easily.
I would take it by a dealer or club member...
Good luck
Old Aug 4, 2012 | 04:06 AM
AdvanZ33's Avatar
AdvanZ33
Senior Super Moderator
It's "glued" from the factory. A good method is to have 2 vice grips and some rags. Clamp one set on the shifter itself and the other on the shift **** base. Use the rags to protect the shift boot and **** from getting damaged. Hold the shifter vice grips firmly in place while rotating the shift **** grips counter clock wise. DO NOT try and loosen the shift **** without securing the shifter, you can damage the linkage. Good luck.
Old Aug 4, 2012 | 05:01 AM
KingBaby's Avatar
KingBaby
Hardest Setting
Nice to know, my shif **** literally twisted off at first attempt.
Old Aug 4, 2012 | 05:06 AM
AdvanZ33's Avatar
AdvanZ33
The 2 that I've taken off were a pain! I felt like something was going to snap. Here's a helpful link OP:
http://nissanhelp.com/diy/z/projects...ob_removal.php
Old Aug 4, 2012 | 05:40 AM
ocdz's Avatar
ocdz
I remember reading once that the 03 and 04s were the hardest to remove. My 03 was nearly impossible.
I resorted to a medium pipe wrench to get leverage on the kn.ob and used a large vice grip on the linkage to hold it from rotating. It finally busted the glue or thread lock with a large pop, then easily threaded off. This method will destroy the stock kn.ob!
Old Aug 4, 2012 | 06:02 AM
stogey420time's Avatar
stogey420time
Club Moderator
the Hot Spot
I remember my '05 was impossible to take out. Broke the factory glue and thought I was good... no! Keep on twisting left to where the boot can't twist anymore and the **** isn't out yet... wtf
Reach to the point where I gave up and re-tighten the **** where the boot is back in its original position. Changed my mind and turn it back to the left then back to the right (couple times) then turn it left and boom it's off.
Weird.
Old Aug 4, 2012 | 06:26 AM
taywan's Avatar
taywan
Me too!!
Old Aug 4, 2012 | 08:32 AM
graffkid732's Avatar
graffkid732
Good luck. I destroyed my factory shift **** taking it off. Such a pain in the ***.
Old Aug 4, 2012 | 09:40 AM
big_dish's Avatar
big_dish
As already said, its a huge pain.
Also, as already said, MAKE SURE YOU SECURE THE SHAFT with another set of vice grips... you will cost yourself a sh*t ton more money and problems if you dont do this... I cannot stress enough- use two pairs of vice grips, one on the shifter and one on the shaft. Good luck.
Old Aug 4, 2012 | 09:52 AM
ZS14RR's Avatar
ZS14RR
You need some huevos
Old Aug 4, 2012 | 11:05 AM
Cristhian702's Avatar
Cristhian702
Did the clutch on my 07 a couple months ago and couldn't break it loose. I believe I tweaked the linkage just a bit now my fifth is just off at a slight angle used no vice grips nothing but my juevos as stated above and nothing! I ended up taking the shifter completely off. Now I must realign the linkage.
Old Aug 4, 2012 | 12:04 PM
kennyy's Avatar
kennyy
Thanks for the info and links guys! Ill give it another shot today!
Old Aug 4, 2012 | 01:27 PM
terrasmak's Avatar
I've removed a few now, simple as using two hands to turn it. The simple task may become a man card requirement soon.
Old Aug 4, 2012 | 03:40 PM
kennyy's Avatar
kennyy
did you use vice grips?
Old Aug 4, 2012 | 04:55 PM
terrasmak's Avatar
Nope
Old Aug 8, 2012 | 10:56 PM
DiZeaZed's Avatar
DiZeaZed
This is what I used http://www.chicagoz.com/forums/showthread.php?t=19951 it helped me out tons!!!
Old Aug 9, 2012 | 04:25 AM
bender's Avatar
bender
You have to have a pair of locking pliers on the shift lever under the boot. Not only will it prevent possible transmission problems, but it keeps the shift lever from flexing and moving. If you don't, the shift lever will give a little and flex while you turn. You want all your strength going to the ****, not wasted taking the lever with it.
Lift the shifter panel and get a good grip on the shift lever with locking pliers. Keep it as straight as possible and make sure it doesn't move while you turn the ****. Start off using your hand with a glove on. If you've exhausted that solution, use a rubber strap wrench. DON'T use a normal wrench. It won't grip the ****! It'll just chew it up and make the whole process even worse.
Old Aug 9, 2012 | 08:50 AM
TPete19's Avatar
TPete19
I removed mine easily using a pair of 10" channel locks to secure the actual shifter and turned the **** by hand.
No damage to OEM shift **** = half your $ back from buying aftermarket
sherm
Apr 11, 2020 05:21 PM
Fixxxercask
Cooling System
Nov 5, 2015 03:21 AM
EnjukuRacing
Sep 30, 2015 06:55 AM
