Upgrade 04-06 z headlights conversion
Maybe someone can help me on here. I wanna get rid of mt 04 headlights and put the 06-09 lights on my car how does it work i heard theres one wire that is not in use on the 06 headlight ? Any feedback
Ah no, thats not quite correct^
the headlights are plug and play but will light your turn bulb all the time unless you cut one of the wires and the turn signal, blue wire i believe.. taillights take no wiring whatsoever. they are fully plug and play.
Thats what I meant they said one of the wires are not in use or that would happen. So what do you do with the wireing so you dont have that problem with the signal lights ? also are the bulb fitment different I have HIDS on my 04 I think there H1
Searching will yield this answer. It's been covered plenty of times.
i went from 03 to 08 headlights and there was no wire cutting for the headlights. i didnt have any issue with the turn bulbs. The rear had 3 wires to mess with to convert to the led tailights. difference in headlight styles?
Yea my back taillights are already converted wanted change the headlights now. What a difference it makes on the car 06-09 headlights make the car look like 2013 if you mod em rite with LEDS **** looks bad ***.
The wire is still connected to the bulb socket, but you are killing the physical connection between the end of the wire and the bulb prong. Hence, no constant on turn signal.
