Interior suggestions?
Old Jan 5, 2013 | 09:57 PM
drvqz33's Avatar
drvqz33
So does this mean the door panel's ruined? or can you easily remove it?
Looks like it was hot glued..
Old Jan 6, 2013 | 06:44 AM
vex008's Avatar
vex008
props for diy
think you should redo in black. cut out speaker round. going to look too clashy if you cut out speaker with grey.
Old Jan 6, 2013 | 07:56 AM
ZMoneyPIT's Avatar
ZMoneyPIT
My buddy re-did his oem seats with alcantera. It looks pretty good. The only thing is he took time making it look perfect pulling apart every section of his seats getting an oem look. I think if you really put tons of effort into it you could get something clean and you would like.
Old Jan 6, 2013 | 02:00 PM
Teha99's Avatar
Teha99
I used the proper 3M adhesive lol not hot glue. I dont know if the door panel is ruined or not, Ill have to see if I can take off the suede, and sand off the glue. If not then I will have to buy another one...
Old Jan 6, 2013 | 03:46 PM
ParanoidAndroid's Avatar
ParanoidAndroid
lolol thanks for the laugh
Old Jan 6, 2013 | 06:40 PM
drvqz33's Avatar
drvqz33
Gotcha. Well if you need door panels, I have a pair of immaculate 03-05 ones that i've just recently taken off. Upgraded to 06+ ones
And I wouldn't sand it, try some adhesive remover
Old Jan 7, 2013 | 10:44 AM
Teha99's Avatar
Teha99
Yea I will definitely let you know. I am pretty much done for this season as Im back in college and away from my car...
Old Jan 10, 2013 | 11:57 AM
DrummerGirl's Avatar
DrummerGirl
I like the suede idea, but I don't like how you executed it.
As for the rest of the interior, it depends on what you're looking for. There's plenty that could be upgraded, so you need to decide what your goal is and go from there. For example, you might want a black/silver color scheme, so maybe some silver stitching for the door handle leather, a new steering wheel w/ silver stitch, upgrade the odometer and get black/silver gauge face w/ white LEDs, a new shift ****, new shift boot, maybe do something with the rear strut bar and paint the door switch panels to match the center console....that's a lot though. I don't know how far you want to go with your car, but those are just some ideas.
Goodluck with the upgrading, I'm interested to see what you end up doing.
Old Jan 14, 2013 | 08:17 AM
TPete19's Avatar
TPete19
OP,
People are being surprisingly harsh. This has all the potential in the world. Maybe it's just due to the pictures being so washed out, but keep your chin up.
I've done some 'faux' suede wrapping in mine so I can tell you that it looks great when it is done right. The biggest issue I see is that you didn't separate the door panel in order to fully wrap the fabric around the middle edge and it doesn't appear that you fully wrapped around the window edge either... You MUST wrap the fabric around the edges.
Keep trying.
Old Jan 15, 2013 | 04:13 PM
Teha99's Avatar
Teha99
Thanks. I took the panel off but I thought if I wrapped the edges it might not fit. I guess I have to sand down the edges to compensate for the extra material. Its a learning process
Old Jan 16, 2013 | 08:09 AM
TPete19's Avatar
TPete19
You shouldn't need to sand down any edges. The only place I ever needed to do that was on my waterfall cubby door. Non-moving parts should be fine. Heck, the tighter fit could look better than OEM in spots.
Old Jan 18, 2013 | 12:23 AM
samsniss350z's Avatar
samsniss350z
Are there different qualities of this faux Alcantara and suede available cos i really don't want to be rude but this really does look cheap. I've been thinking of doing this to my car but this has really put me off until i can find out more about this material and if there are different qualities available.
Old Jan 18, 2013 | 02:02 AM
SilverStone2003's Avatar
SilverStone2003
You can tuck the edges, just cut a slit or hole for the door clips. it should fit fine. No grinding to compensate for the material thickness or any of that stuff. I think it would look great if done properly.Your only issue would be tucking by the window, hopefully not moving the material up and down when you roll the window up and down if you know what im saying.
Old Jan 18, 2013 | 09:19 AM
TPete19's Avatar
TPete19
Yes there are different quality versions. I did some wrapping in my interior and used upholstery quality microfiber. Typically runs $25-30 per yard. The cheaper stuff is stretchier and easier to work with, but it looks like a$$.
Old Jan 20, 2013 | 11:05 AM
Teha99's Avatar
Teha99
Yea there are different types but I made sure I got the straight up fabric with no stretch cause that was what I found out through the other threads. It ran sticker price at $24.95/yd and I only wanted two but they had like 2.5 so I got an extra .5 yds for free
3vilbunny
Jul 18, 2017 05:10 PM
HoBrahYouStink
Jun 24, 2016 10:58 PM
