Gauge Mount in door
Old Apr 21, 2013 | 09:22 PM
wls350's Avatar
wls350
Default Gauge Mount in door
Not sure if this is in the right place but here goes
was asked to post a small write up.
I had a damaged air vent in drivers door, so i decided to put my wide band AFR into the vent.
Pull door out get vent out completely
Split it from the clips behind
Behind the Vent
Put gauge in to see it fits 52mm
Took a dremmel to the Inside of the clip just work through it bit by bit until the gauge fits flush on either side
Once fitted i Used some epoxy to tack it on either side of the vent
Covered it in Red Vinal (going to plastidip this rather)
Final product
Note
ran the wire through the speaker cable insert down to the Fuse box, where i wired it up.
Undeneath i had the bung welded in just below where the manifold joins (works a charm) ran the cables up and through the brake fluid area.
And the final outlay
FYI while i had door of i sprayed the interior parts aswell
And ill throw this in just for the hell of it
i put a samsung p6200 tablet into my cubby area.
Old Apr 22, 2013 | 05:17 AM
taywan's Avatar
taywan
Nice! I saw that you were going to post this. I've been wanting to get an oil temp and put it in mine since I already have a triple above that. Looks good!! Thanks for sharing.
Old Apr 22, 2013 | 05:26 AM
secwind's Avatar
secwind
Nice write up! Thanks for doing this.
Old Apr 22, 2013 | 04:50 PM
MadCow's Avatar
MadCow
That looks great. Just one question. Any condensation?
Old Apr 22, 2013 | 04:56 PM
terrasmak's Avatar
That is exactly where I want to try look while driving.
Old Apr 22, 2013 | 06:36 PM
wls350's Avatar
wls350
Actually put an afr as a tuning tool for myself, it's surprisingly easy to catch it out corner of your eye when tracking ect, but not the intended purpose.
On a dyno at least u can see live when making changes ect
No condensation at all hey, but I live in a fantastic climate
Old May 10, 2013 | 09:09 PM
l2iceman's Avatar
l2iceman
any detailed pics on the tablet install?
Old May 11, 2013 | 04:10 AM
03stampededak's Avatar
03stampededak
^+1. Smallish android tablet running tourque would be very useful!
Old May 12, 2013 | 02:42 PM
hardtoocatch's Avatar
hardtoocatch
when u ran the wires to the fuse box where did u grab the power from???
Old Feb 28, 2014 | 10:41 AM
wls350's Avatar
wls350
Ignition for power
Sent from my GT-I9300 using IB AutoGroup
