Question about painting the strut bar
Old May 25, 2013 | 12:31 PM
JaimeNismo's Avatar
JaimeNismo
Default Question about painting the strut bar
What will happen f I paint the strut bar on my 350z engine? Will it start to chip because it will be so hot?
And I will be using primer first.
Old May 25, 2013 | 12:49 PM
ZMoneyPIT's Avatar
ZMoneyPIT
OP I would highly suggest not doing this. The strut bar has been put through many tests and a uneven paint coat would end up screwing your suspension by putting more weight on one side of the car. Don't mess with OEM things unless you want tons of problems in the future and thousands in repairs.
... Use heat resistant paint!
Old May 25, 2013 | 01:40 PM
JaimeNismo's Avatar
JaimeNismo
I thought you being serious at first.
But ok thanks.
But ok thanks.
Old May 25, 2013 | 01:47 PM
dcains's Avatar
dcains
It's a small part - so, it will be inexpensive to get it powdercoated or hydrodipped.
Old May 25, 2013 | 02:16 PM
samsniss350z's Avatar
samsniss350z
Better still buy a strut bar that looks the business otherwise you're going to end up with a standard strut bar that has been painted and is going to look like a standard strut bar that has been painted and unless the paint is really really good its going to make your standard strut look crap. Check out the market place on here or check fleabay, moreover check out photo's of cars with aftermarket strut bars and just see how hot some of them look and how crap a painted strut bar would look against them.
Old May 25, 2013 | 03:33 PM
engiNERD350Z's Avatar
engiNERD350Z
You'll be fine man. Use heat resistant paint. No primer needed. All I did was make sure it was perfectly clean to paint. I painted mine over 5 years ago, no chips, no flakes, or anything.
Old May 25, 2013 | 03:35 PM
Flick Montana's Avatar
Flick Montana
Just use brake caliper paint or engine paint and you're fine.
Old May 25, 2013 | 04:05 PM
HanoverZ's Avatar
HanoverZ
Get it powder coated as previously mentioned.
Old May 25, 2013 | 04:34 PM
07zforce's Avatar
07zforce
any automotive finish will work fine with clear coat it will never chip or peal if done right ,heat is not a problem just ask yourself one question how hot do you think a hood gets on any summer day in Arizona the desert hot enough too cook an egg on it so you will be fine .I painted a vortech supercharger with automotive paint never any issues. good luck
Old May 26, 2013 | 09:06 AM
JCITY's Avatar
JCITY
You'd be better off just buying a cool aftermarket strut bar.
If you insist on painting yours(what color&why?),do it so you get pro
results or,its gonna look ricer.Powder coat or depending on the color,
do a heat resistant wrinkle finish for a Euro look.
Old May 26, 2013 | 09:20 AM
mr. sparco's Avatar
mr. sparco
Get a cheap eBay strut bar instead, it's only ~40 bucks.
Old May 26, 2013 | 12:23 PM
350Z Project X's Avatar
350Z Project X
i painted an aftermarket sport jdm one I got a few years ago flat black and red. Ill have to find some pics of it. Its thicker than stock and I can feel the difference with the 2
Old May 26, 2013 | 07:20 PM
DarkCreep's Avatar
DarkCreep
Get it powder coated, you wont regret it.
But since youre being cheap and are looking for cheap mods, any paint will be fine. Dont make it tacky please.
issyz
Jul 2, 2017 03:04 PM
HoBrahYouStink
Jun 24, 2016 10:58 PM
Dark Knight
Wheels Tires
Nov 11, 2015 08:40 PM
