Carbon Fiber Restoration
Old May 27, 2013 | 05:30 PM
Jurgen's Avatar
Jurgen
Default Carbon Fiber Restoration
Hey guys Need some ideas about what to do, the sun have destroyed my rear wing and front spoiler.(Seibon)
Any way to restore it? a least the spoiler
The car was washed every Saturday and waxed every couple of months the wing probably need to be redone or plasticdip the bad area.
Ideas and suggestion welcome
Thanks
Attached Thumbnails Carbon Fiber Restoration-img_20130527_153907.jpg   Carbon Fiber Restoration-img_20130527_153922.jpg
Old May 27, 2013 | 05:34 PM
taryon's Avatar
taryon
I think reclearing them would help
Old May 27, 2013 | 05:42 PM
Cux350z's Avatar
Cux350z
hatersgonnahate
light sand and reclear
Old May 27, 2013 | 09:29 PM
samsniss350z's Avatar
samsniss350z
As Cux350z says rub down with fine wet and dry until you've got rid of the bad bits and then get it clearcoated to protect it again. Keep plastidip well away from it, that'll make it look godawfull
Old May 28, 2013 | 11:28 AM
Chebosto's Avatar
Chebosto
most CF that comes out from china is not UV clear'd. just with gel coat.
this will be hard to fix since the damage is to the resin/gel coat.
sanding might help a little bit. but you may still see some of the lines/ghosting from the previous damage.
Old May 28, 2013 | 02:36 PM
Jurgen's Avatar
Jurgen
Thanks for the replies
I'm going to do the clear coat temporary and see what happen.
I live across the street from the Biscayne Bay and park at work less than 50 ft from the water so I don't expect it to last much, but hope the car look better or I will have to paint the parts the same color of the car.
thanks
Old May 29, 2013 | 11:26 PM
Waiz's Avatar
Waiz
thanks
You will need to sand it otherwise the damage will still show through the clear
I went through something similar when I repaired my NISMO B-pillars
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
