Wet sanding for dull paint?
Old Jun 2, 2013 | 10:45 PM
Fun40zx's Avatar
Fun40zx
Default Wet sanding for dull paint?
My redline z is starting to get oxidized so I'm thinking about getting it detailed since I got hit by some chick that ran a red light . They told me about 300 to wetsand and buff . Is that reasonable? I have no experience with paint and polishing and detailing. Help me out guys .
Old Jun 3, 2013 | 09:47 AM
logan09's Avatar
logan09
Wetsand? sounds like they don't know what they're talking about
I guess it depends on location but here the shop will do it for 150 and that has no wetsanding involved. Just a wax strip, clay bar, polish-paint correction, and seal/wax.The only reason for wetsanding I guess would be to fix a bad scratch, but seeing as you said you got hit thats possible.
Actually, go into the detailing section of the forums and do some research.You should be able to do this yourself with a bit of time, and way less money
Old Jun 3, 2013 | 04:11 PM
KornerCarver's Avatar
KornerCarver
Invest some money into a good dual action buffer and you should be able to do the job yourself. You can get everything you need for $300 and then you can keep your car in immaculate condition.
Old Jun 3, 2013 | 06:56 PM
mr. sparco's Avatar
mr. sparco
Depends on how bad the clear coat is, 2-3,000 grit wet/color sanding is used for paint that's very oxidized. Using rubbing compound to cut the paint isn't always enough to get a glass finish. Wet sanding is a step above your basic detailer who just does a buff/polish/wax.
Old Jun 3, 2013 | 07:34 PM
350zchad's Avatar
350zchad
i charge 600-1500 for paint correction.. wet sanding would def. add more to that tab.. dont think id trust the person that said they would wet sand and buff?? what are they buffing? after wet sanding, they need to at least compound, then polish, then seal.. not to mention the many other steps a pro will do.. no way it will be a professional job that cheap!
Old Jun 5, 2013 | 10:18 AM
STL 350Z's Avatar
STL 350Z
$300? Run.... run far far away.
There's no way someone can do that type of work unless they are severely under pricing their work. Post pics so we can see what you are dealing with and recommend a course of action you can do yourself.
Old Jun 5, 2013 | 03:30 PM
Fun40zx's Avatar
Fun40zx
I'll post a picture later tonight. He's charging me 300 I guess cause he's going to paint my front bumper and hood from the accident I was In. But I have to ask him if he's going to compound polish and seal. Also I've noticed that the paint in my car is kinda thin as my mirrors are already cracking from the clear coat .
Old Jun 5, 2013 | 05:11 PM
Fun40zx's Avatar
Fun40zx
<a href="http://s845.photobucket.com/user/fun40sx/media/image-3.jpg.html" target="_blank"><img src="http://i845.photobucket.com/albums/ab16/fun40sx/image-3.jpg" border="0" alt=" photo image-3.jpg"/></a>
<a href="http://s845.photobucket.com/user/fun40sx/media/image-2.jpg.html" target="_blank"><img src="http://i845.photobucket.com/albums/ab16/fun40sx/image-2.jpg" border="0" alt=" photo image-2.jpg"/></a>
Old Jun 5, 2013 | 05:15 PM
Fun40zx's Avatar
Fun40zx
Here's the hit from the accident all cause she was late to school and ran the red
<a href="http://s845.photobucket.com/user/fun40sx/media/image-4.jpg.html" target="_blank"><img src="http://i845.photobucket.com/albums/ab16/fun40sx/image-4.jpg" border="0" alt=" photo image-4.jpg"/></a>
Old Jun 5, 2013 | 05:34 PM
jhc's Avatar
jhc
General & Tech Moderator
Sorry you got hit, man! Red is a hard color...fades fast usually. If your guy is gonna spray front end, I'd see what he wants to get it all the same shade. Good luck, and post up pics after!
Old Jun 6, 2013 | 07:49 AM
STL 350Z's Avatar
STL 350Z
Looks like bad oxidation from never being waxed/protected. If it were me I'd hit it with some Dawn dish detergent to strip the surface, clay, then something like Meguair's M105 and M205 with several orange lake country ccs pads make to remove oxidation and swirls, then a white or red pad for glaze and wax/sealant.
Old Jun 6, 2013 | 09:47 AM
tquill's Avatar
tquill
I agree that wetsanding probably isn't necessary on the back (don't really know)... but I'd rather just pay someone to do it. I'd rather not buy a ton of equipment that I'll almost never use. I'd recommend going to the autopia forum and finding a local detailer who is a regular on the site.
Old Jun 6, 2013 | 09:57 AM
Jeff92se's Avatar
Jeff92se
Wetsanding with like a 2000 grit paper is pretty close to some really aggressive polishing compounds. But like others have said, that's too cheap. There's 2-3 steps at least to be taken. Plus a final wax
Old Aug 2, 2013 | 01:09 PM
Fun40zx's Avatar
Fun40zx
So I decided to go with the v2 but I'm not sure if I like the the look very much.
Rev_Night
Nov 7, 2020 06:00 PM
Cashwin
Oct 1, 2015 06:36 AM
