Problems after soft top replaced
Well, the upholstery shop took off the back panel under back hatch, and found the small blue lever switch was broke. This seems to be why it wouldn't complete the process of closing. I found a front passenger piece, where the top latches into, and it has a switch that looks identical. Does anyone know if these are all the same? Or will I need to order one from the hatch area?
Thank you!
Thank you!
Thank you!
Thank you!
You would think they'd offer to do it. At this point, I want them as far away from my Z as possible. Should've known...if you want something done right, ya gotta do it yourself.
