Cleaning up my Bixenon headlights, what compound should I use??
Old Jul 15, 2013 | 03:31 PM
User 42426's Avatar
User 42426
Default Cleaning up my Bixenon headlights, what compound should I use??
Hey guys,
Tried polishing my headlights and looks like I failed. I don't have a drill, so used everything by hand.
I wet sanded using several different types of sandpaper from 600 grit up to 1500
I used plastix to polish by hand but the haze is there as the plastix wasn't able to polish up or get out the fine scratches left by wetsanding.
I was going to seal it after, but want to redo it so it looks brand new.
I used to have some mothers rubbing compound, its brown/mud like in color and it was for getting out small scratches on the body of the car. Can I use that or should I buy polishing compound instead, does it matter which one? And what do you guys recommend I use? Thanks!
Old Jul 15, 2013 | 03:49 PM
KornerCarver's Avatar
KornerCarver
You probably need to go to 2000 and then 3000 grit sandpaper. I would also suggest investing in a drill. You can get one pretty cheaply at Harbor Freight.
Old Jul 15, 2013 | 04:32 PM
DCJodon's Avatar
DCJodon
3M rubbing compound is the beez kneez.
Old Jul 15, 2013 | 05:11 PM
BY350z's Avatar
BY350z
Forget about sanding, polishing, and sealing. Once you remove the factory UV coat your headlights are done, your best solution is to buy some cheap ebay headlights and remove the lenses and transfer them to your old headlights
Old Jul 15, 2013 | 09:45 PM
User 42426's Avatar
User 42426
So after wetsanding, I should use 3m rubbing compound with a drill, then plastix, then seal?
Uriyo_
Sep 8, 2021 08:46 AM
Dsowe
Feb 17, 2021 10:38 AM
_bit
Oct 2, 2015 07:49 AM
EnjukuRacing
Sep 30, 2015 06:55 AM
JGee450
Sep 30, 2015 04:32 AM
