Depo 06+ style headlights and other aftermarket headlights thread
Old Nov 8, 2014 | 05:31 AM
  #661
Knifey McStabb's Avatar
Knifey McStabb
ive been creeping this thread forever and im thinking about getting a set of these for my 05. my base non hid's are HORRIBLE at night! i just hate the extra hassle of having to convert the connectors.
Old Dec 8, 2014 | 11:14 PM
  #662
DarkCreep's Avatar
DarkCreep
Even with HID's 03 05 lights are still horrible for night time driving.
Old Dec 10, 2014 | 07:25 AM
  #663
NOLAGG's Avatar
NOLAGG
Since I got these I've been getting terrible condensation in my driver side head light. I just ordered 10 gram silica packets as a quick fix for winter to see if it helps.I'll let you guys know for those who night be having the same problem due to them not coming sealed correctly.
Old Dec 16, 2014 | 12:04 PM
  #664
Nexx's Avatar
Nexx
currently on sale on ebay for $233 shipped for the pair! http://www.ebay.com/itm/Depo-Performance-Pair-315-1162PXUSH2-Headlights-For-Nissan-350Z-/331405589984?pt=Motors_Car_Truck_Parts_Accessories&fits=Model%3A350Z&hash=item4d294ffde0&vxp=mtr
Old Dec 18, 2014 | 07:17 PM
  #665
akuma69's Avatar
akuma69
Default Aftermarket 350z LED headlights?
Hi guys has anyone tried something like this?
http://www.ebay.com....=item2a41b49b5a
It looks good. Looks unique and adds the LEDness to 350z. My wife telling me to buy that and put it on.....haha!!
Old Dec 18, 2014 | 07:21 PM
  #666
mr. sparco's Avatar
mr. sparco
Link doesn't work and we already have an ebay headlight thread. 06+ oem or depo oem replacement is what you want. Most ebay headlights are frowned upon.
Old Dec 27, 2014 | 11:12 AM
  #667
NOLAGG's Avatar
NOLAGG
Just wanted to update every one,I put the silica packets in the light and after many rain storms no more condensation (for now).
Old Dec 31, 2014 | 05:23 AM
  #668
G4nismo's Avatar
G4nismo
pretty creative thinking i'd say sir
Old Dec 31, 2014 | 06:33 AM
  #669
92K1500's Avatar
92K1500
Originally Posted by 92K1500
If there is a lot of moisture (humidity) in the housing it is going to keep doing this. Gotta get the moisture out of the air inside the housing to keep it from condensing on the lens.
It can be perfectly sealed but if there is a lot of moisture trapped in the air inside the sealed housing it will continue to do this.
Might try using some silica packets out of beef jerky and the such inside the housing to soak it up and keep it from happening again. (and making sure all the joints/caps are sealed.)
Why thank you!
Glad it worked for you. It's not a perminant fix because it will eventually soak up all the moisture it can but hopefully it will last you a while since it's such a pain to get to.
Old Dec 31, 2014 | 07:04 PM
  #670
NOLAGG's Avatar
NOLAGG
Why thank you!
Yea thanks man just until the winter is over here in nyc
Old Jan 1, 2015 | 11:50 AM
  #671
quakerroatmeal's Avatar
quakerroatmeal
Where's the condensation coming from? Can't you reseal the entire housing?
Old Jan 1, 2015 | 09:26 PM
  #672
JSia's Avatar
JSia
quakerroatmeal whats up brah
Old Jan 4, 2015 | 05:40 AM
  #673
92K1500's Avatar
92K1500
It's mainly from moisture trapped inside. It can be from a leaky seal or from it being hot/humid when you have the cap off the back side. Then when it cools off it will condensate on the lens just like your drink glass does.
If you have it sealed up good and it's getting int here some silica packets like NOLAGG used will clear it up and hopefully prevent you from having problems again.
Old Jan 4, 2015 | 09:35 AM
  #674
NOLAGG's Avatar
NOLAGG
3 weeks with crazy climate change and rain and still perfect.I did how ever take a heat gun to the light until I saw all the moisture out. a hair dryer won't work well at all, so don't bother unless you have s heat gun.
Old Jan 21, 2015 | 05:55 PM
  #675
absurdparadox's Avatar
absurdparadox
I have an 03 Track (with HID's of course) that I'm trying to swap some Depos on to, and I'm having a problem getting the HID bulb to turn on. Everything else seems to work fine, and I tested it with the old stock bulb, which also did not light up (but does on my stock unit) -- thus it should not be the bulb itself
I thought it was plug n play aside from me getting a D2S bulb, which I did. Did I miss something here? I did notice that my stock connector has 8 pins and the depo connector matches, but is missing a pin (both are that way).
Any help appreciated.
Old Jan 22, 2015 | 02:56 AM
  #676
NOLAGG's Avatar
NOLAGG
Still no moisture, woo.
Old Jan 22, 2015 | 02:57 AM
  #677
NOLAGG's Avatar
NOLAGG
Wait what's the problem?
Old Jan 22, 2015 | 06:49 AM
  #678
absurdparadox
In the depo unit, the HID bulb won't turn on (tested the bulb, and it works fine).
I have an 03 with HIDs stock -- I thought it was plug and play as long as I got the correct bulb (which I did), so I am wondering if there is some sort of mod to the wiring harness or something I have to do to make it work?
Going to try the other depo headlight tonight, and if it works, I know its a problem with the harness on the first depo unit.
Old Jan 22, 2015 | 02:31 PM
  #679
92K1500's Avatar
92K1500
Is your ground arm doohickey touching the side of the igniter? They used that instead of the little ground strap wire in the 03-05 housings.
Old Jan 25, 2015 | 06:50 PM
  #680
350zEric's Avatar
350zEric
bit the bullet and bought a set with the ballast and bulbs (aftermarket).
my question is i have 03-05 non hid setup (base, halogen) that was retro fitted with ddm tuning hid kit (original owner, getting rid of these). how will i be able to get these to work since they are 8 pin and the oem halogen was 6 pin? searching online i just need to get a compatible harness and other say i need to do wiring modification. not quiet sure how to approach this as most of the threads are plug and play scenario.
