None of my lights are working!! Fuse maybe?
Old Jan 27, 2004 | 07:35 PM
Webiteks's Avatar
Webiteks
Default None of my lights are working!! Fuse maybe?
I installed the LED Parking lights by Ares and my right parking light wasn't working. I went ahead and switched it out with a backup LED Light I bought, and it worked for 3 Seconds, then ALL OF MY LIGHTS STOPPED WORKING!
Here are the lights that are not working:
* Parking Lights
* Blinkers / Emergency Flashers
* License plate lights
I read the owners manual front and back, located the fuse boxes (thinking that maybe I just blew a fuse) - and there is not a fuse just for these lights. . . what happened!????
Does anyone have any suggestions??
-Chris
Old Jan 27, 2004 | 08:47 PM
Webiteks's Avatar
Webiteks
Update::
* I just checked EVERY FUSE in my car (just as a precaution) and EVERY FUSE is perfectly fine.
* I also just noticed that my brake lights do not come on either with my parking lights. . . however, when I press on my brakes - they come one.
MY SUMMARY:
EVERY LIGHT that is supposed to come in when you turn on your parking lights. . . DO NOT come on. In addtion, my blinkers don't work either.
I hope someone can give me some assistance!
Old Jan 28, 2004 | 06:40 AM
2003z's Avatar
2003z
did you check the fuse box thats behind the battery? I blew a lighting fuse and looked for over an hour for the damn fusebox. Thats where the lighting fuses are. (not the one thats just in front of the battery, but another fusebox in that area)
Old Jan 28, 2004 | 08:40 AM
Webiteks's Avatar
Webiteks
I just looked and saw that fuse box hidden back there. I will check that right now. I see I have to talk off my cowl top and everything to even get to it! Hopefully it's a fuse in there.
Old Jan 28, 2004 | 12:30 PM
Webiteks's Avatar
Webiteks
::UPDATE::
Found the problem. It was a fuse located in the IPDM E/R Fuse Box. Just replaced the 10A fuse and everything is good to go.
The only downside is that I have the factory Parking lights back in becuase I don't want to take a chance of blowing the fuse again :-)
Old Jan 28, 2004 | 01:25 PM
silverstoneTT's Avatar
silverstoneTT
I hope that doesn't happen to me when I put mine in. Where is the IPDM fuse box?
Old Jan 28, 2004 | 01:59 PM
ares's Avatar
ares
Veteran
located behind the battery.
kyin
Oct 15, 2015 05:54 AM
Sleeper_Z
Sep 30, 2015 10:25 AM
samansharif
Sep 25, 2015 12:31 PM
