350z and Bucket Seats
Old Oct 15, 2013 | 05:01 PM
booozy's Avatar
booozy
Default 350z and Bucket Seats
Is there a way to use a fixed back bucket seat and side mount rails with the stock seat belts? I was thinking maybe I could unhook the bottom of the seatbelt, string it through the left side harness hole in the seat, and then just string it through the other side when I need to put it on. I would really rather not use harnesses because this is my daily
Old Oct 15, 2013 | 05:31 PM
bealljk's Avatar
bealljk
you can string the permanently mounted side just fine but what are you gonna do with the buckle side? string that through too? and mount the receptacle to the seat rail bolt?
if you are dead set in adding legit bucket seats than put a seat belt bar in like the sparco bar.
Old Oct 15, 2013 | 05:35 PM
booozy's Avatar
booozy
well i would string it through when its buckled, and then it would be only strung through one when its unbuckled, can you tell what i mean?
Old Oct 15, 2013 | 05:38 PM
bealljk's Avatar
bealljk
I know what you mean…it'll look terrible, it'll jeopardize your safety and how are you going to mount the buckle receptacle?
Old Oct 15, 2013 | 05:46 PM
pyshin's Avatar
pyshin
Why can't you just buy some nice semi-bucket seats (the stocks are already "semi-buckets") and just keep your stock belt exactly as-is...
Why do you need a full bucket seat?
Old Oct 15, 2013 | 05:47 PM
booozy's Avatar
booozy
http://honda-tech.com/attachment.php...1&d=1258219570
Most sets of seat rails have a little nut for mount the stock buckle. How would it reduce my safety? Im not really bent on doing this but im not really seeing how this could jeopardize safety
Old Oct 15, 2013 | 05:57 PM
booozy's Avatar
booozy
I already have a bucket seat, and haha what? the stock seats are about as buckety as a park bench
Old Oct 15, 2013 | 06:02 PM
pyshin's Avatar
pyshin
^^^ Hence the quotations. It was sarcasm, lol.
I see that you upgraded from a 240. Thats awesome, I see useless 240's all of the time with bucket seats for literally no reason at all.
If you're going to track your Z. Great. Get at least a harness bar and secure yourself properly.
But if not, I don't see really why you want to install a full bucket in a daily. What's your justification? Just the fact that you have one laying around?
Old Oct 15, 2013 | 06:09 PM
booozy's Avatar
booozy
Sorry, its hard to tell over the internet. Yeah thats the thing, its my daily, and i would like to do parking lot autocross events sometimes. Therefore a harness would be overkill.
Is this sarcasm too? its because im a ricer
Old Oct 15, 2013 | 06:25 PM
pyshin's Avatar
pyshin
Everything is sarcasm.
It's your Z, do whatever you'd like. Ricericerice.
Old Oct 15, 2013 | 06:29 PM
booozy's Avatar
booozy
mmmk but anyways, has anybody tried this?
Old Oct 15, 2013 | 06:43 PM
samsniss350z's Avatar
samsniss350z
Why not save yourself the ballache of fitting a bucket seat and/or harness and just go out and buy yourself a CG-Lock, Its a great bit of kit and is nearly as good as fitting a harness without all of the hassle. It keeps the lap section of your standard belt locked tight and holding you in your seat. I know one of these was used in the Toyota sprint series without the need of bucket seat or harness.
Old Oct 15, 2013 | 07:26 PM
booozy's Avatar
booozy
thats actually really neat, im definitely looking into this
Old Oct 15, 2013 | 09:00 PM
terrasmak's Avatar
People have done it , you will need a buckle off another Nissan that is webbing mounted to thread thru the inner location.
Old Oct 16, 2013 | 02:56 AM
booozy's Avatar
booozy
Do you know what car has that?
Old Oct 16, 2013 | 03:19 AM
SQuaLZ's Avatar
SQuaLZ
Have you ever sat inside fixed seats?
I was set on getting a pair for my car until I sat in a few cars with them. If I got them I would have hated my car during commutes.
Since mine is the same as yours, a daily with occasional autox, I reccomend staying with the stock seat and belt, since I was thinking the same exact thing as you recently.
The only fixed seat I would consider is the Recaro Pole Position as it was not THAT bad.
If I eventually do get seats, I will be getting reclinable seats.
I highly suggest sitting in fixed seats so you can get an idea of how uncomfortable you will be during commutes. Your back will hate you.
Old Oct 16, 2013 | 06:00 AM
QuintonC's Avatar
QuintonC
1.) Sit inside seats to get a feel for what you want.
2.) You're on the right track, look up a few install threads of bucket seats and your question will be answered.
3.) Smile
4.) Go broke after ordering seats.
5.) Profit
Old Oct 16, 2013 | 06:32 AM
terrasmak's Avatar
No idea , a member on here did it a few years back.
Also, if you have airbags in your OEM seats, do not swap to aftermarket.
Old Oct 16, 2013 | 11:26 AM
booozy's Avatar
booozy
yes ive driven in a low car with stiff suspension for long periods of time in this seat, ill be fine
stuartc323's Avatar
stuartc323
OP the CG lock is gold, I suggest learning the car first, than upgrading it from stock. The car was built really well
