Headlight mystery
Old Nov 3, 2013 | 09:53 AM
KTR5's Avatar
KTR5
Default Headlight mystery
My drivers side low beam is not working. I've replaced the fuse. It didn't look blown, but replaced it anyways. I've replaced and checked the bulb. I've replaced the ballast and ignitor and tested it on the passenger side so I know each part works. But low beam is still not working. The other lights work (high, parking, turning) and the passenger side unit works completely.
It's a 2003 Performance model.
Any other suggestions to find the problem?
Old Nov 3, 2013 | 10:52 AM
ordinaryme's Avatar
ordinaryme
same thing with my 2007
Old Nov 3, 2013 | 09:01 PM
mcubed45's Avatar
mcubed45
Check the signal on the harness connecting the headlight to the car? Do you get power from the appropriate pins? Since you've already eliminated bulb/ballast/ignitor as the problem, just keep working your way upstream.
Uriyo_
Sep 8, 2021 08:46 AM
Dsowe
Feb 17, 2021 10:38 AM
JGee450
Sep 30, 2015 04:32 AM
TrboMike
North East
Sep 28, 2015 06:36 PM
Kilroy.Bukowski
Sep 26, 2015 11:24 AM
