installed full size carbon fiber cooling plate
Old Feb 3, 2004 | 01:27 PM
mofoz's Avatar
mofoz
oh, i believe this will add 20whp and 15lbs tq
Old Feb 3, 2004 | 01:34 PM
Phatmitzu's Avatar
Phatmitzu
Or I have $100 too much no where to spend...
Old Feb 3, 2004 | 06:21 PM
B2BigAl's Avatar
B2BigAl
Holy cow, all I need is a cooling plate and one of those "power modules" off ebay and I'll be pushin 320+ hp!! Beware corvette owners!! j/k
Old Feb 3, 2004 | 06:43 PM
BJF2K's Avatar
BJF2K
haha what the heck are those modules anyways... anyone here bought those?
Old Feb 3, 2004 | 08:15 PM
mofoz's Avatar
mofoz
there was one that was just a glorified grounding kit and it was sealed unbelieveable tight so taht it could not be x-rayed or taken apart to see what's inside. funny stuff.
Old Feb 10, 2004 | 02:02 AM
apsilon's Avatar
apsilon
Originally posted by ypwpat
apsilon, regarding the large intake of US and ours in AUS is the same. I install one my self here and have the same gap on the intake. So i guess the AUS Version intake is already the Same as US version.
Sorry, missed this post.
I have a US duct on the way so I guess we'll find out soon enough. I had assumed that given our cars are basically JDM spec in other areas this would be the same.
Old Feb 10, 2004 | 02:07 AM
ypwpat's Avatar
ypwpat
yeah we'll see and i'm looking forward as well Btw where did you buy the duct from? is it from Performance nissan?
Old Feb 10, 2004 | 02:10 AM
mchapman's Avatar
mchapman
I've compared the images on the other page with the ones from the original air duct post and if what he says is true, its not looking good.
Old Feb 10, 2004 | 02:14 AM
apsilon's Avatar
apsilon
Yes from Performance Nissan.
Old Feb 10, 2004 | 02:39 AM
ypwpat's Avatar
ypwpat
apsilon i maybe wrong. Maybe the US airduct is slightly bigger. Sorry about it . i didn't really notice it much because the size is pretty small or just my angle photo shot is different. Don't it's pretty hard to distinguish from it.
here is mine on the picture
Attached Thumbnails installed full size carbon fiber cooling plate-p1010040.jpg
Old Feb 10, 2004 | 02:40 AM
ypwpat's Avatar
ypwpat
another one from different angle
Attached Thumbnails installed full size carbon fiber cooling plate-p1010041.jpg
Old Feb 10, 2004 | 11:04 AM
apsilon's Avatar
apsilon
I'll know for sure probably this week and will post results.
Old Feb 11, 2004 | 06:42 PM
Sponge's Avatar
Sponge
I got an aluminum cover today from StrictlyZ. Came really fast and it looks great.
I went to install the thing this evening and DAMN. Let me state first that I AM mechanically inclined. How do those damn plastic pop rivets come out. Mine are in SO TIGHT! I popped the center piece and it unlocks but as hard as I pull I can't get any one of them to come out. I think I'm pulling fairly hard using a needle nosed plyers around the "popped" part of the rivet for leverage and still no go. Guess I'll wait til tomorrow when I can see things a little more clearly.
Any suggestions? I'm listening.
Old Feb 11, 2004 | 06:47 PM
ypwpat's Avatar
ypwpat
use a flat head screw driver (smallest one or a small one) and you can pop them easily or you can use a knife to pop it up
Old Feb 11, 2004 | 07:04 PM
Sponge's Avatar
Sponge
My rivets "pop" but they are very securely held in the hole for some reason.
Old Feb 11, 2004 | 07:06 PM
ypwpat's Avatar
ypwpat
as i said use the flat head screw driver on the base of it. But if that only you don't mind to scratch a bit the paint work on it. which for me i don't mind because it will be covered anyway.
or you mind want to use a cloth cover it and pull with your whole strength using your finger :P
Old Feb 11, 2004 | 07:19 PM
3pointer's Avatar
3pointer
The trick is pop the rivert up but NOT all the way up. Once it comes lose, grab the bottom part of the clip (NOT the insert) and pull it. It should come right off.
Old Feb 11, 2004 | 07:23 PM
  #38
fdao's Avatar
fdao
It's actually quite easy to pull it out. You don't need any muscles . What you have to do is after popping the rivets, you have to grab near the distal end and not at the base. You then just gently wiggle the rivet out of the hole.
Old Feb 11, 2004 | 09:13 PM
  #39
Phatmitzu's Avatar
Phatmitzu
Exactly. The harder you pull the insert...the tighter it will get.
Old Mar 4, 2004 | 08:50 AM
  #40
Phatmitzu's Avatar
Phatmitzu
Thumbs up Real Carbon Fiber Cooling Plate Group Buy at it Again!!
New Real Carbon Fiber Cooling Plate group buy going on now!
https://my350z.com/forum/showthread....8&pagenumber=2
