Passenger Window Weather Seal Above Mirror Part # ??
Old Mar 28, 2014 | 10:29 PM
BIGPOPPAPUMP's Avatar
BIGPOPPAPUMP
Default Passenger Window Weather Seal Above Mirror Part # ??
I let someone work on my car & it looks like they either opened or closed my doors with the battery disconnected & window couldn't lower to clear the roof.
It tore that seal that is above the mirror assembly but goes over passenger winder near hinge. I am looking for a part number, a place to find it or a suitable or common fix? It isn't clear on the print.
If you open you door & look at the top of your side window it is the seal above your side view mirror. All I thought I had was air getting in the car at high speeds. The problem took a long time to locate. I would vastly appreciate this info. If just a certain size weather striping can be used at a specific length, that would be good as well. Thanks.
Old Jul 1, 2014 | 06:49 PM
cashmoney03's Avatar
cashmoney03
Did you ever find something? I need the same part for my drivers side.
_bit
Oct 2, 2015 07:49 AM
350z82
Oct 1, 2015 06:25 PM
samansharif
Sep 25, 2015 12:31 PM
