Headlight help??
Old Apr 13, 2014 | 07:06 PM
Hornlesscow's Avatar
Hornlesscow
Default Headlight help??
so i dont know much about headlights and ive ran my vin a couple times they said i have factory hid but the dumb owner before me put in a aftermarket h7 kit and now i dont know if they were truely factory hid or not how can i tell because i need new housings and idk which to buy. if it helps there is a silver block inside the housing which im assuming is the factory HID ballast but there a no wires connecting so can anyone help me out i need to order some depos tonight
and i have a 03 touring with orange heated leather seats and cruise control.
Old Apr 13, 2014 | 07:10 PM
CJM's Avatar
CJM
I believe all touring models came with HID lights
Old Apr 13, 2014 | 07:15 PM
Hornlesscow
so does that mean i have to buy new bulbs and wiring harnesses? because it looked like he ghetto rigged the h7's in the housing and i dont want to be drillng screws into my new housings
Old Apr 13, 2014 | 07:44 PM
gregom's Avatar
gregom
Yeah Touring has factory HID. Are H7 for the highbeams? Maybe the previous owner put HID's on the highbeam as well. The 03-05 Z's with factory HID still have halogen for the highbeam.
Take the headlamp out, on the bottom of the headlamp there should be a black HID ballast that says "Matsushita", that is a factory HID ballast. It should be plugged into the wiring harness on the headlamp. Wiring goes inside the headlamp to the HID bulb. So the wiring to the low beam bulb should be coming from inside the headlamp housing.
If you can take a couple pics for us that would really help.
Old Apr 13, 2014 | 08:19 PM
Hornlesscow
thanks man ill take some pictures tomorrow but im pretty sure there is a black ballast attached to some silver metal looking wires only problem is the ballast itself isnt attached to the low beams because im using a aftermarket ballast and i know they are h7's im not sure about the high beams though but the lows are definitely h7's
Old Apr 14, 2014 | 05:26 AM
KornerCarver's Avatar
KornerCarver
I suspect you have a set of Base model headlights. The Base uses H-7 for the low beams and H-1 for the high beams. The models equipped with HID's use H-7 for the high beam and D2R for the low beam. You say your low beam is H-7 and I doubt that a socket for the D2R would allow an H-7 to seat properly. Double check your lights and see if you have H-1 high beams. If so, I am certain you have the Base model headlight housings.
Uriyo_
Sep 8, 2021 08:46 AM
Dsowe
Feb 17, 2021 10:38 AM
JGee450
Sep 30, 2015 04:32 AM
TrboMike
North East
Sep 28, 2015 06:36 PM
Kilroy.Bukowski
Sep 26, 2015 11:24 AM
