I have been looking for this and I dont want to spend 400 dollars on it. I don't what brand what it is made out of or anything like that. I know the charge speed piece is probably dry carbon fiber and all that good stuff, but I just don't need all that. I just need a cover for a blemish. If anyone knows where to find one could you share?
Good luck, if its bad fitment and quality don't try to install it and just return it instead
+1 for wrapping it or leaving it alone instead, just save for a real lip instead of a taped on front accent that has no real effect on anything
What do you mean by real lip? If I have to save up for it is probably way too expensive. There is no point in putting expensive lips on a car that you DD. I WILL get messed up.
well i got it and guess what. the fitment sucks. big gap on the left side.i had to drive with it on for a week until i was able to get it off.(double sided taped on). Think i just wasted $170 ...definitely would not recommend
Use a heat gun to reshape it if it doesn't fit correctly.
can you help me out? im scared to mess with it.. oh yea im still down for the cf interior wrap btw..after looking at it again i think moving the left side up and sanding the right side down a lil bit might work
