Electrical Gremlins
Old Jun 10, 2014 | 05:06 PM
Resmarted's Avatar
Resmarted
Default Electrical Gremlins
They've got me scratching my head. I went to start the car up today (after a LONG build) and well a few things popped out. Mainly the fact that I have no power to my constant power wire (yellow going into radio) and my turnsignal relay makes no noise and have no lighting on the inside turn signals. No beeping when the door opens either. A few weeks ago this wasn't the case; I just had no light/noise on inside turn signals. Upper gauges work (factory harness to oil pressure/voltage/mph) but not the radio. My accessory power lines work, and so do all the other lights in the car. Power windows work aswell. I pulled out and inspected all the fuses next to the dead pedal/clutch pedal and did the same for the ones behind the factory battery location.
Thoughts?
I am considering just running another power wire to my aftermarket gauges and giving an FU to the radio, but I have a feeling there must be issues elsewhere. Car does crank over.
Fixed this issue. Everything works as it should
Whiskers1996
Tuning
Aug 1, 2020 04:09 PM
BOATS N HOES
Lighting
Oct 13, 2015 09:07 AM
Katie93
Sep 15, 2015 05:57 PM
PureR3d
Sep 10, 2015 06:23 PM
