Broken door mirror question
Old Nov 17, 2015 | 09:57 AM
vside's Avatar
vside
Default Broken door mirror question
Hi guys, I was at a light waiting for the green light. The signal turned green and I proceeded to go when I noticed a parked car's door opening . You can imagine what happened next. Yup, their door killed my passenger door mirror. I have an 03 without the heat option and was wondering if I could use one from a donor car that has the heated mirror option? I know that it won't give me a heated mirror but I just want to make sure the electrical connection will still work for the mirror functionality. BTW, the other guy's insurance if paying for the damage and already cut me the check.
Thanks,
J
Old Nov 17, 2015 | 10:22 AM
Heritage's Avatar
Heritage
There is no reason you cannot use the heated mirror; the bolts are the same. There is just a wiring harness that feeds through a hole in the door. Just ziptie it to something so it doesn't rattle around.
Old Nov 17, 2015 | 10:38 AM
jhc's Avatar
jhc
General & Tech Moderator
Not sure if this helps,
http://www.courtesyparts.com/nissan/...position=right
Old Nov 17, 2015 | 11:26 AM
vside's Avatar
vside
Thanks for the info, I will post back once I determine if the swap affects the original mirror motion.
Old Nov 17, 2015 | 11:41 AM
dkmura's Avatar
dkmura
General & DIY Moderator
Never heard of a heated mirror option on ANY of the Z33s. The electrical connections are for the mirror adjustments, not for any heaters in either of the side mirrors.
Old Nov 17, 2015 | 11:44 AM
vside's Avatar
vside
That's what the insurance adjuster told me??? I know my 03 has a three wire plug, the ones I've seen labeled as "heated" for sale on ebay have a five wire connection.
Old Nov 17, 2015 | 12:28 PM
Russ@Z1's Avatar
Russ@Z1
Yeah, my 03 touring came with heated mirrors. Controlled by the rear window defroster switch.
Old Nov 18, 2015 | 11:21 AM
myork's Avatar
myork
My 06 has heated mirrors as well.
dkmura
Oct 14, 2015 05:45 AM
BWL
Oct 31, 2011 09:42 PM
4NTOY II
North East Marketplace
May 20, 2011 10:24 AM
yojack1
Northern California
Jul 18, 2007 02:27 PM
Sillent Killer
Aug 7, 2003 10:31 AM
