aluminum center pieces
Old Dec 10, 2015 | 04:49 AM
thrawn33's Avatar
thrawn33
Default aluminum center pieces
so i just wanted to put this out there. i have been looking at refinishing my two aluminum center pieces on my 2004 touring edition. every forum i have been to says that these pieces are plastic. this is only partially correct. i took apart the steering wheel last night (props to all those write ups i found) and removed the cruise control switch from the right side. sanded down the clear coat and lo and behold, the fronts are aluminum. any ideas on painting? i kind like the silver color, so i thought about sanding and refinishing and then applying a new clear coat. any thoughts? i'll throw some photo's up when i get home. do not try and use vinyl paint as it does not stick (i have had to sand it again after i tried, kind of a dur hur moment ).
Old Dec 10, 2015 | 06:09 AM
jhc's Avatar
jhc
General & Tech Moderator
My topcoat was thinning, so I just pulled them and removed it with a little acetone. Better than new.
Old Dec 10, 2015 | 05:08 PM
Joe clan's Avatar
Joe clan
Wrap in vinyl?
armt350z
Dec 30, 2015 09:53 AM
MDK
Brakes
Dec 14, 2015 04:59 PM
ry4ndavis
Dec 13, 2015 03:23 PM
thrawn33
South East Marketplace
Dec 9, 2015 10:23 AM
