Drivers side Inside door handle *vein*
Old Jan 11, 2016 | 09:24 AM
leonchus's Avatar
leonchus
Default Drivers side Inside door handle *vein*
Hey guys, my driver's side door handle stopped working. Heard a click and something fell in the door. What yall suggest I do?
Old Jan 11, 2016 | 09:42 AM
turboed350z's Avatar
turboed350z
I mean... its not like the obvious thing to do would be to remove the panel and see what broke....
Old Jan 11, 2016 | 09:49 AM
travlee's Avatar
travlee
Master
go to the texas/mexico border, they can x-ray your car and see what is broken
Old Jan 11, 2016 | 09:56 AM
dkmura's Avatar
dkmura
General & DIY Moderator
The door latch is operated by a small metallic ball on the end of the cable that operates the latch. Either the door handle hook or the cable itself has likely broken. You'll need to pull the door panel itself (SEARCH for the DIY on this) to open it up and find out yourself, or take it to a Nissan dealer and let them work on it if you not a DIYer.
Old Jan 11, 2016 | 10:52 AM
dcains's Avatar
dcains
I'd suggest a faith healer, or perhaps acupuncture.
Old Jan 11, 2016 | 03:23 PM
leonchus's Avatar
leonchus
Respect for that I think thats what it is aswell, jus wandered if I can reconnect something or jus buy a whole new door handle. ( I dont have time and knowledge to strip down my door panel, for the smart asses)
Old Jan 11, 2016 | 03:44 PM
MicVelo's Avatar
350Z/370Z Tech Moderator
As dkmura said, it's either going to be the ball at the end of the cable OR..... MORE THAN LIKELY (ask me how I know), the latch that said ball connects to broke off. It's a cheap piece of nylon that, over the years, gets brittle. Only way I know of to repair is to replace the door handle - of which the nylon latch is integral.
Repair isn't that difficult. You have to remove the panel and disconnect the window switches and that's far less difficult than it sounds....
https://my350z.com/forum/exterior-an...oval-help.html
The handle itself is held on with a couple of screws. Screw new one after connecting the ball connector and done.
Or take it to Nissan.
Old Jan 11, 2016 | 04:08 PM
beezee's Avatar
beezee
Honestly the only way to fix this yourself is to remove the door panel as suggested above. In the process you learn more about the car. Nothing hard. Dealership will charge too much for something that simple. Good luck.
Vas_Z33
Exterior
32
Apr 18, 2016 07:22 AM
ukraini9mofo
Jan 25, 2016 05:02 AM
terrj
Jan 8, 2016 04:51 AM
savedbygrace
Jan 2, 2016 08:10 PM
savedbygrace
Jan 1, 2016 10:43 PM
