Door wiring help.
Old Jan 12, 2016 | 02:42 PM
David Womacks's Avatar
David Womacks
Default Door wiring help.
Im swapping my 04 door panels for 06+ panels and want to hookup the LED in the cup holder,Im not sure which wire in the door to splice into, I guess what I need is a source that gets shut off when the car does.
Thanks
David
Old Jan 12, 2016 | 02:55 PM
jhc's Avatar
jhc
General & Tech Moderator
Hi David, and welcome! Not sure what you trim level is, but my 06 Touring has a bulb. Leds are super easy, and not polarity dependent.
So if you do have a bulb, remove your inside door panel and either use but connectors or 3M splice-ins to get your power. Hot glue or silicone with clamps for an hour.
Good luck, and post up pics so we can see your project!
Old Jan 12, 2016 | 03:46 PM
karlt's Avatar
karlt
Actually they are.
Old Jan 12, 2016 | 04:51 PM
jhc's Avatar
jhc
Dunno. My drls worked either way.
Old Jan 12, 2016 | 08:14 PM
dcains's Avatar
dcains
Thanks
David
Why don't you have a meter you can check your wiring with?
Old Jan 12, 2016 | 10:48 PM
David Womacks
My door panels have the LED built in but my car is an 04 so there is no LED plug so what I'm trying to find out is which two wires to tap into for power and ground on both the drivers and passenger side
Old Jan 13, 2016 | 03:41 AM
dcains's Avatar
dcains
Etekcity MU600 Digital Multimeter / DMM / Multi Tester with hFE Measurement - - Amazon.com Etekcity MU600 Digital Multimeter / DMM / Multi Tester with hFE Measurement - - Amazon.com
Old Jan 13, 2016 | 07:11 AM
David Womacks
I know how to find a 12v with the multi meter but what is a good ground to use? Im really kinda a noob at wiring beyond audio.
Old Jan 13, 2016 | 08:08 AM
dcains's Avatar
dcains
Look at the lighting circuit for the window switches.
Old Jan 13, 2016 | 09:26 AM
David Womacks
Any idea on what color the wires that power those LED are?
Detailed Image
Cleaning & Detailing
Jan 12, 2016 04:49 AM
leonchus
Jan 11, 2016 04:08 PM
terrj
Jan 8, 2016 04:51 AM
manny1274
Tuning
Jan 7, 2016 05:34 PM
