Manual Cloth to Powered Leather (searched)
Old Aug 25, 2016 | 01:30 PM
NR350z's Avatar
NR350z
Default Manual Cloth to Powered Leather (searched)
Recently bought a set of leather burnt orange seats for my 03 enthusiast. A few specific questions, the seller gave me the stock switches, the seats are from an 03 and I have an 03, is there any type of plug and play? What I've read has given me conflicting answers.
Also, I've read that some use the cig lighter for a power of the seats, but was told it doesn't draw enough current to power the seat motors. Can you use the lighter for power for the seats (not heat)? If not, what do most use as power ?
Thanks.
Old Aug 25, 2016 | 09:24 PM
terrasmak's Avatar
Plug and play, plugs are tucked away. If you want to run seat heaters you need the switches , short harness and a relay to make it all work.
I need to list my switches and harness again
Old Aug 26, 2016 | 12:43 PM
NR350z's Avatar
NR350z
Where are they tucked? (for power?)
Also, previous owner of seats gave me the heater switches, is there a part no. for harness and relay needed?
Old Aug 26, 2016 | 01:11 PM
NR350z's Avatar
NR350z
Here's a picture of the switches and harness the previous owner provided me with
Old Aug 26, 2016 | 04:03 PM
terrasmak's Avatar
Harness is tucked under the carpet and wrapped in tape
Old Aug 27, 2016 | 12:23 PM
NR350z's Avatar
NR350z
So I pulled the pass seat out and pulled up the carpet...
Doesn't look like my car came wired for the seats, and looks like I will have to wire them up myself...
At this time, I don't drive the car in the winter so the heat isn't imperative, whats the best thing to use to power them? Ive been told the cigg lighter could be used but may not draw enough current?
Reference the harness above, can I just swap out this harness for the seated heats to make them work?
(the circled plug doesn't look like it has enough wires coming out of it for the seat heater function, could be wrong tho)
Old Aug 28, 2016 | 11:59 AM
NR350z's Avatar
NR350z
So after doing some more research, I'm still a little clueless, now that I have to wire it up myself, the bottom of the seat is all Greek to me, which wires do i tap for power and ground, not worried about heaters at the moment
Old Aug 28, 2016 | 06:59 PM
NR350z's Avatar
NR350z
Anyone? Just need to know which wires to tap, all I want is power to the seats, I have supplied a picture of the underside of both pass and driver seat, along with the plug I suspect I need to tap but not sure. PLEASE HELP!!!
Drivers side:
Passenger side:
Old Sep 3, 2016 | 09:02 AM
NR350z's Avatar
NR350z
Well a little update in case some people are looking to do the same thing and had the same question(s) as me. As suspected, it was the zoomed in plugs pictured above (switch side of plug), I tapped into them (red for power, black for ground) and tested on a battery to ensure they worked properly before install. Cig lighter is sufficient enough to power the seats, I haven't worried about the heaters yet.
Well, here is the finished working product below!
All in all, wiring, old seat removal, install... took a little over 2 hours...
Old Sep 3, 2016 | 08:22 PM
dcains's Avatar
dcains
Looks great - nice job.
Old Sep 4, 2016 | 08:57 PM
ZedFed's Avatar
ZedFed
This is the exact color seats I have but manual. Something about that black and caramel color really vibes with me lol. Nice setup! So exotic
Old Sep 6, 2016 | 07:38 AM
nizmo_0385's Avatar
nizmo_0385
Can you post some pics of how you tapped the wires I've never done wiring but want to do the same on my nismo
Old Sep 6, 2016 | 08:59 AM
NR350z's Avatar
NR350z
I I just used T-Taps, tapped into the red, and ran it to the cig lighter and then T-tapped the black and went under a seat bracket bolt for the ground.
Not sure if it matters but I tapped into the switch side on the plug. Sorry I didn't take any pics and I would have to pull them out to take one, fairly simple, but I only drive the car in the summer and therefore wasn't worried about the heating function.
Hope this helps
Old Sep 6, 2016 | 09:01 AM
NR350z's Avatar
NR350z
THANKS!! Yeah I love it ! I didn't know they made those seats in manual.
Old Sep 6, 2016 | 09:02 AM
NR350z's Avatar
NR350z
Thank you.
jmathus16
Nov 4, 2018 09:32 AM
Golden_Armz
Wheels Tires
Jun 27, 2016 09:46 AM
mcubed45
Jun 3, 2016 12:28 PM
Lloydjsiemens
Tuning
Jun 2, 2016 07:03 AM
