Where to tap for DRL in engine bay
Old Sep 13, 2016 | 03:05 PM
mcubed45's Avatar
mcubed45
Default Where to tap for DRL in engine bay
I'm in the process of doing some headlight mods. I'd like to run some of the lights as DRL's so I was wondering where the easiest place is to tap for a +12 source that's powered when the car is on. Ideally someplace fairly close to the headlights so I don't have to run too much wire. It'd be great if there's a spot on each side, but I can always run wire across to the opposite headlight as well.
I'd just be running some LED halo's and LED ironman side panels off of it so the current draw shouldn't be an issue.
Thanks!
Old Sep 13, 2016 | 04:25 PM
rottingcat's Avatar
rottingcat
Second hidden fuse box in the where the battery is
I tapped one of the fuses, I think it was windshield or something.
Use a voltometer to check voltage when the car is off if it does not give off a 12v then it will when ignition is on
I used this way to power my halos and LED's
Old Sep 14, 2016 | 01:49 AM
mcubed45's Avatar
mcubed45
Cool thanks. I'll poke around in there.
I think I read somewhere that the windshield sprayer pumps are powered when the car is on and are ground triggered by the switch in the column? That would be a very convenient place to tap into if hat's true.
Actually if anyone knows which circuits are powered temporarily even after the car is off (like the windows) that'd be even better. It'd be nifty if the DRLs stayed on for a bit.
Old Sep 14, 2016 | 03:05 AM
92K1500's Avatar
92K1500
I tapped my halos/fog lights into my marker lights when I put my new headlight housings in. They aren't bright enough to be seen during the day so I just want them on with the marker lights. Then the relay gets power only when the marker lights are on and I have a switch on the ground side to power the fog lights so none of them can get left on and if they do they will shut off after the headlights time out instead of killing my battery.
Old Sep 14, 2016 | 03:06 AM
92K1500's Avatar
92K1500
The headlight circuit is the only one I know of. If you leave your lights on they will time out after 3-5 minutes.
Old Sep 14, 2016 | 11:07 AM
mcubed45's Avatar
mcubed45
I'm using ZLEDS LED halo's/side panels. They're way brighter than the older CCFL mods and visible during the day so I'd definitely like them to turn on with the car rather than only with the parking lights.
Here they are on Staisman's car:
Old Sep 18, 2016 | 03:28 AM
92K1500's Avatar
92K1500
You might hook it to the DRL wire in the headlight harness. I've never tested that plug but I know it runs the turn signal bulb when the car is on.When you turn the turn signal off it should cut power so it could be like the newer cars that kill the DRL when you turn on the signal to make the turn signal more distinct.
apolloautolight
Body Exterior
Sep 14, 2016 10:46 AM
Dblock55
Exterior
Sep 13, 2016 01:24 PM
crazyjeys
Sep 13, 2016 10:47 AM
Dartys zz
Sep 11, 2016 02:42 PM
