Swap 07? Power vert seats to 04 base doable?
Old Oct 20, 2016 | 02:58 PM
Daniel Salinas's Avatar
Daniel Salinas
Default Swap 07? Power vert seats to 04 base doable?
Hey everybody first time post. I've been scouring all the older posts regarding this issue need to see if I can find someone who can help me wire the convertible passenger seat into my 04 base 350. I am seriously stuck and am tired of popping fuses.
Old Oct 21, 2016 | 09:03 AM
Daniel Salinas
Bump
Old Oct 21, 2016 | 11:04 AM
jhc's Avatar
jhc
General & Tech Moderator
The only things that are wired are fore/aft, and recline. Make sure the fuse amperage is correct.
2 things to note:
1) If your base model doesn't have heated seat switches, that clearly won't work.
2) The roadster has a seat back switch that moves the passenger forward and not get hit by the moving top.
You could get a volt meter and try to understand which wire does what, or go to a salvage yard and get the roadster matching connector to replace your old base harness. gl!
Old Oct 21, 2016 | 12:49 PM
Daniel Salinas
thx jhc. i live in tx. so wont be doing the heated seat thing. Need to figure out the bypass for the pass seat tilt back and the forward/backward to work with the seat switches. Dont know much about electrical, the wire colors are hard to figure out and I dont know which wires from which plugs to tap. ANY help would.......help. hahaha.
heres the closeset forum link i could find for my problems.
https://my350z.com/forum/exterior-an...ease-look.html
