Passenger power seat in a base help Please look
Old Dec 9, 2012 | 01:17 PM
hcenteno21's Avatar
hcenteno21
Default Passenger power seat in a base help Please look
I put power leather seats on my base 2007 Z however i got the drivers all wired up and working, but I cannot figure out the passenger. There are a lot more wires, a white box, and i cant figure out what is power and ground for the motors. I have read up and searched just about everything but cannot find an answer.
Old Dec 9, 2012 | 01:41 PM
DavesZ#3's Avatar
DavesZ#3
See this?
https://my350z.com/forum/body-interi...seat-swap.html
Old Dec 9, 2012 | 01:49 PM
hcenteno21's Avatar
hcenteno21
Originally Posted by DavesZ#3
I read every post of that thread 3 times. I got my drivers no problem, but my passenger has a bunch of wires, and a white box. I just want power, not worried bout heated seats.
Old Dec 9, 2012 | 02:02 PM
Cux350z's Avatar
Cux350z
hatersgonnahate
look for a 4 or 6 pin connector. Pins 1 and 2 are power and 3/4 are to the motor.
Pins 1 and 2 will feed the switch. 1 is +24 and 2 is 0vdc
Old Dec 9, 2012 | 02:07 PM
hcenteno21's Avatar
hcenteno21
the switch connects to a 6 pin connector...but it only has 5 wire...
top row
black w white stripe no wire baby blue
bottom row
yellow geen orange
that then routes to the white box...i am tried all types of combinations
Old Dec 9, 2012 | 02:08 PM
hcenteno21's Avatar
hcenteno21
btw i am a total noob dont know what +24 is or 0vdc
Old Dec 9, 2012 | 02:13 PM
hcenteno21's Avatar
hcenteno21
here is an image of what i am looking at...
Old Dec 9, 2012 | 02:30 PM
Cux350z's Avatar
Cux350z
hatersgonnahate
sorry it should be +12v and 0vdc which is your battery voltage.
That is a lot of connectors. I was looking at a 2003 FSM.
The top two pins would be the power and the bottom 4 for motor control if this was out of a 2003 but since it is not...idk. The looks like an extra controller of some sort.
Old Dec 9, 2012 | 02:31 PM
winchman's Avatar
winchman
There are wiring diagrams and info on how to use them in the service manual.
Old Dec 9, 2012 | 02:40 PM
hcenteno21's Avatar
hcenteno21
its out of an 07....
Old Dec 9, 2012 | 02:52 PM
Cux350z's Avatar
Cux350z
hatersgonnahate
06 appears to be the same as 2003. Sorry, i do not have a 2007 FSM to look through.
+12v on red, 0v on black.
doing some more looking. Did these come out of a roadster by any chance? They seem to have a controller on the passenger side.
Old Dec 9, 2012 | 02:58 PM
Cux350z's Avatar
Cux350z
hatersgonnahate
also does it recline and go fwd/backward electrically?
Can you get me the wire colors of the connector. All 5, i think i found it in the FSM. Lots off connections for it probably because of roadster.
Old Dec 9, 2012 | 02:59 PM
hcenteno21's Avatar
hcenteno21
im not 100% certain...but theres only the switch to move the seat...no controller..? I really appreciate your help. The drivers was so simple, but this one has become a nightmare! I can't figure it out.
Old Dec 9, 2012 | 03:01 PM
hcenteno21's Avatar
hcenteno21
yes one sec...they do recline...and it has button on back seat as well...
Cux350z's Avatar
Cux350z
hatersgonnahate
are the colors
Red
Green/yellow
Black
White
Red/black
Old Dec 9, 2012 | 03:03 PM
Cux350z's Avatar
Cux350z
hatersgonnahate
I am not a seat expert by any means for the years but my non roadster only moves FWD by motor, recline is by manual handle.
It appears the roadster checks the reclined position and whether or not someone is buckled up. I believe before you put the top down it checks position and trys to move the seat to clear the top.
hcenteno21's Avatar
hcenteno21
the switch to move seat connects to the a connector and these are the colors
top row
black with white stripe blank baby blue
bottom row
yellow green orange
Old Dec 9, 2012 | 03:07 PM
Cux350z's Avatar
Cux350z
hatersgonnahate
thats not the right connector. That should go straight to the controller. The black and white stripe wire should be 0vdc/tied to ground
Old Dec 9, 2012 | 03:09 PM
Cux350z's Avatar
Cux350z
hatersgonnahate
whats the colors of the wires on that loose connector on the bottom left of your pic.
Also it looks like the motor is unplugged.
We go try this two ways, splice and get rid of the controller completely or try to wire it up with the controller and jumper out some signals.
Old Dec 9, 2012 | 03:11 PM
Cux350z's Avatar
Cux350z
hatersgonnahate
on the connector you called out
Orange and Green are for the reclining motor power
Yellow and light blue are for the forward/reverse
Black white is the ground
Problem is that this switch is not the same as the driver side. The drivers side switches both the + and - to change motor directions where this switch provides ground signals to the controller to do the directions.
Looks like we need the controller to make this work.
