Best phone holder
Old Mar 29, 2023 | 06:59 AM
i8acobra's Avatar
i8acobra
I think the most retarded thing I've read all year is "best Phone Mounting system... 350z Drift Car".
Old Mar 29, 2023 | 07:06 AM
Heel Til I Die's Avatar
Heel Til I Die
How else are you supposed to live stream while doing sick drifts?
Old Mar 29, 2023 | 10:27 AM
johnrdadrian's Avatar
johnrdadrian
it's a small minded individual that criticizes and condemns, yet can't provide a superior solution. The incongruity is glaringly obvious.
The brilliance in the design submitted is in its simplicity.
Old Mar 29, 2023 | 03:34 PM
Dan Garcia's Avatar
Dan Garcia
Old Mar 29, 2023 | 03:35 PM
Dan Garcia's Avatar
Dan Garcia
The magnetic plate can be replaced with any type of phone cradle, the panavise products are very versatile
Old Mar 29, 2023 | 11:50 PM
johnrdadrian
On the plus side, I assume you could just close the cubby hole and your phone holder is out of sight. For some this is enough of a reason to use a setup like this.
But:
-Your cubby cant be used to store anything
-Your phone doesn't charge while driving
-If you use this system, you have to drive with the cubby open while using this holder.
Would it be possible to attach a wireless phone charger to the underside of the cubby door?
-Something that still allows some storage in the cubby, but when you close the door, the phone charger is out of sight...
-Something like the "iBOLT 17mm Dual Ball to AMPs Drill Base Mount Compatible w/ 17mm GPS Brackets Phone Holders" combined with a Wireless Charger.
See Link: https://a.co/d/iZenbnz
See Link: https://a.co/d/8BRSHSz
Old Mar 30, 2023 | 04:19 AM
Dan Garcia's Avatar
Dan Garcia
But:
-Your cubby cant be used to store anything === True, i only kept a set of glasses in there so was ok with trading over the storage for the phone holder, much more convenient.
-Your phone doesn't charge while driving ==== true, i use a charging cable, but the charger base can be incorporated in my set up, or you can go with the set up from the attached links.
-If you use this system, you have to drive with the cubby open while using this holder.===== yes, door can be closed when not in use.
-Something like the "iBOLT 17mm Dual Ball to AMPs Drill Base Mount Compatible w/ 17mm GPS Brackets Phone Holders" combined with a Wireless Charger. === i am sure the suggested set up can be made to work.
i like all the panavise gadgets and have used them in the past, plus eBay has a very large inventory of panavise hardware, so i just bought the parts that i felt would complete my set up.
see notes in bold above
Old Mar 30, 2023 | 06:14 AM
i8acobra's Avatar
i8acobra
You clearly missed the point. My condemnation is not of the design. This is how we get Dugans.
bobinsofla
Apr 21, 2014 06:10 PM
AznSky
Photography
Oct 19, 2010 10:15 AM
firexbomber
Apr 28, 2010 05:45 PM
theonetheonly
Jul 5, 2004 02:18 PM
