Missing interior panels help
Old Apr 25, 2017 | 05:55 PM
BrookZee's Avatar
BrookZee
Question Missing interior panels help
Alright guys so I recently bought an 03 track model 350z. I noticed a couple of interior panels missing. First: Directly next to the VDC button there is a hole in the panel. No wiring is loose in the area so I'm assuming its just a cover. Maybe in a different model an actual button would be there? Anyways id like someone to confirm what should go there. And if at all possible id like to replace the missing panel but i have no idea what to search for considering I don't know what it missing.
missing panel number 1
Second: I also notice the OBD hangs loose. It appears as though their should be some kind of panel that the OBD clips into here? Can someone confirm this? Like the last panel id also like to replace this missing panel. Any ideas what these panels are and how i can get new ones? Thanks everyone for any info.
Missing panel #2
Old Apr 25, 2017 | 11:29 PM
amr_electron's Avatar
amr_electron
Number 1 is a mask switch, Number 2 is a metal bracket.
Old Apr 26, 2017 | 03:40 AM
The Swede's Avatar
The Swede
Number 1 is the headlight washer toggle switch on european spec cars. Think it's just a blank on US/Jap spec Z's?
Old Apr 26, 2017 | 03:42 AM
travlee's Avatar
travlee
Master
you can find them on courtesyparts.com
Old Apr 26, 2017 | 09:03 PM
BrookZee's Avatar
BrookZee
Thanks everyone who has replied. Everyone here is always nice and informative.
After some research I have found some more info. This is the part number for the OBD metal bracket i have found online: OBD2-UDBRKT can someone confirm this is the correct part?
OBD Metal Bracket picture
In addition i also found a part number for the mask switch: 68492-AX000
Mask Switch Picture
The mask switch i found appears to be the wrong color unfortunately but its the best i have found so far. Someone confirm this is the correct part at least? just wrong color? If anyone has the part number for the correct color that would be nice.
Good to know im not missing anything important. Replacing the panels would be nice but i wont loose sleep over it. Thanks again everyone!
Old May 5, 2017 | 07:05 PM
BrookZee's Avatar
BrookZee
Bump
Old May 5, 2017 | 09:36 PM
dcains's Avatar
dcains
You could also put something like this in that opening next to the VDC switch:
Amazon Amazon
Old May 6, 2017 | 12:37 AM
zwei_the_c's Avatar
zwei_the_c
Regular
5 Year Member
Whoa, the switch placement is different from 06+, I was going to respond to answer but didn't know myself.
I'd throw in a Nitrous switch with 75 shots Zex behind me.
/jokes
Old May 6, 2017 | 01:58 PM
BrookZee's Avatar
BrookZee
https://www.amazon.com/Charger-Futur...5%3A2470955011
Neat item you've found there. Considering I've never even used the factory cigarette lighter to charge a phone or anything though I doubt I would ever use it. Makes me wonder what other kinds of things people have placed in that blank switch space. Bass control or light switch perhaps.
Old May 6, 2017 | 02:00 PM
BrookZee's Avatar
BrookZee
/jokes
Id prefer my Z not to end up wrapped around a pole.
Old May 6, 2017 | 03:34 PM
MicVelo's Avatar
350Z/370Z Tech Moderator
Nice idea. Only problem I'd be concerned about is the cord dangling over the st column or by the pedals. Maybe a short cord going up to a window mount phone keeper.
Or, just pull the plug on my in-car cam and continue to use the rear accessory socket if I need to charge my phone that badly.
