I got a 06 350Z convertible with some problems need help identifying them or advise on fixing
the lock is taped and the door is always open.. I'm guessing the actuator is not working but I want to test it tho I'm afraid I won't be able to open it again
This light is burned but I don't know the name of it or the type of the bulb
This lever is broken, the cable is working properly just isn't attached to the plastic lever can I get a plastic cover or need to replace the whole cable?
The glass for these gauges is in a scratched badly where can I find them?
The switches on the right side of the odometer are in bad shape as well where can I find replacements?
You can access the gas flap solenoid from the trunk behind upholstery, just pull the plunger.
Get a working, matching lever from salvage yard.
The build up/scratches can be removed with toothpaste and a soft cloth. Yes, toothpaste.
gl!
Hey,
e-bay is your friend for some used parts. Also for new, but then no OEM.
I'm thinking about your gauges, that could be the easiest to find, not so easy to change. For removing the console, the forum here contains a lot of inputs, you can also find youtube videos on it.
Headlight can be expensive (700 for a new OEM one).
