changing stock HID color
Old Mar 14, 2004 | 01:15 PM
toykilla's Avatar
toykilla
Default changing stock HID color
can we simply swap the bulbs for a different color temp?
if so, where is the best place to order online?
Old Sep 22, 2009 | 08:16 AM
ZachUA's Avatar
ZachUA
sorry to bump an old thread but I was wondering the same thing and found this post when searching.
What is the oem HID color temp anyway?
Old Sep 22, 2009 | 09:21 AM
LLL'sZ's Avatar
LLL'sZ
DDS OR DDM tuning they are cheap and GOOD! Google it, it gives you the code you need for your car too...
I want 8k or 10k i think our stocks are 4k?
Old Sep 22, 2009 | 10:53 AM
zerafian's Avatar
zerafian
lol, I would have just started your own thread..but at least you used the search tool heh,.
Old Sep 22, 2009 | 11:07 AM
TheFarmer's Avatar
TheFarmer
Stock is 4300k. If you drive a lot at night, 6000k is probably the highest I would go. You start to lose a lot of light output after 6k.
Old Sep 22, 2009 | 11:26 AM
LLL'sZ's Avatar
LLL'sZ
My 8k in the Titan are brighter than i need them to be?
Old Sep 22, 2009 | 12:54 PM
ZachUA's Avatar
ZachUA
I think I am going to go with 6k. What color temp do most cars with HID bulbs come with? I need a D2R bulb, correct? Rock on.
Old Oct 2, 2009 | 08:31 AM
sam2944's Avatar
sam2944
Hello, yes ours Z uses D2R in the lo beam. OEM temp is 4,300k. You get most light from a 5000k bulb, but most people search for a little blue and this is the 6000k. Is more elegant than the 5000k. Thanks, www.sagahid.com If need support on translate contact me personally. My Best!
Old Oct 2, 2009 | 03:54 PM
Kuhan's Avatar
Kuhan
What year is your Z?
I have 08 and mine is D2S.
use this site to find the bulb type
http://www.sylvania.com/ConsumerProd...lacementGuide/
I got these for about 6 months now without any issue. Looks great.
Ebay 6000K
If you like, you can get Philips bulbs (the best out there).
Old Oct 4, 2009 | 06:15 AM
sam2944's Avatar
sam2944
I own a 04, and hi beam is H7. www.sagahid.com
Old Oct 4, 2009 | 05:19 PM
o2sys's Avatar
o2sys
03-05 OEM HID (Pro-flectors) - D2R bulbs
06-08 OEM HID (Projectors) - D2S bulbs
Major difference between the two bulbs is the shading on the bulb. Both work on either headlights though..
seriously if you want better light output change to 06+ headlights first...
Old Oct 4, 2009 | 06:44 PM
Roper215's Avatar
Roper215
Default Phillips Vs other company
I checked out Phillips and the kits come with ballists. The demo video showed them doing a conversion from a halogen to a hid system.
No aftermarket ballists are needed for the 350z are there?
I was under the impression that since we already had HID's no other parts but bulbs would be needed but when going thru the phillips car selection process it has the kit?
Also how much are the bulbs seeing that two pair will be needed for both high and low beams.
Phillips has a single pair priced at 270.
Old Oct 4, 2009 | 08:34 PM
o2sys's Avatar
o2sys
If you have HID's from factory then you do not need a/m ballasts. Only if you are upgrading to a 55W then you need a complete kit (ballast & bulbs).
Vendors here and else where sell bulbs only for around $40~60 for both.
Old Oct 4, 2009 | 10:26 PM
Roper215's Avatar
Roper215
Default Cool
Yeah I have an 08 Touring.
Old Oct 5, 2009 | 03:21 AM
LLL'sZ's Avatar
LLL'sZ
I love how ppl are just like buy the 06 lights first? I mean not many ppl just have that much money to blow on new lights when your's aren't broken......
Who wouldn't want new 06's on their Z's i mean that's a no brainer but to say things like that are strange to me. I can't afford 1800.00 lights but can afford $50.00 hid bulbs for an upgrade,? does that make me a loser or something?
Old Oct 5, 2009 | 04:02 AM
sam2944's Avatar
sam2944
Change bulbs only if you already have HID on the car. You wont loose anything. For hi beam, if desired, you will need the entire kit. www.sagahid.com
Old Oct 5, 2009 | 06:07 AM
o2sys's Avatar
o2sys
haha didn't mean to offend anyone, i know its easier said and done but you don't need to spend $1800 from the stealership. There is a great amount of headlights in our classifieds and i'm sure there are junkyards out there who carry them.
I bought used 06 headlights for $500 here and even found a complete set of brembos from a local junk yard for $400~!!!!
Pleask
Dec 21, 2021 03:17 PM
kyin
Oct 15, 2015 05:54 AM
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
