Help...removing overlays?
Old Mar 15, 2004 | 01:13 PM
MCopare's Avatar
MCopare
Default Help...removing overlays?
Does anyone know how to remove the overlays on the headlights effectively and without scratching the plastic? I tried to use a razor blade but stopped when I scratched the headlight a little. Is there any chemical that will dissolve the vinyl overlay without hurting the plastic housing?
Old Mar 15, 2004 | 01:27 PM
zeroday's Avatar
zeroday
is this one of Bat's overlays? if so did you ask him? why are you removing them?
Old Mar 15, 2004 | 01:38 PM
MCopare's Avatar
MCopare
Just changing up the look......Someone please help.
Old Mar 15, 2004 | 01:43 PM
MCopare's Avatar
MCopare
Old Mar 15, 2004 | 01:50 PM
zillinois's Avatar
zillinois
Hairdryer and razor?
Old Mar 15, 2004 | 04:01 PM
CatastrophZZ's Avatar
CatastrophZZ
well use hair dryer to warm it up as much as you can so that it wouldnt leave any glue behind, then just use your finger and slowly once at a time peeling it. and if it still leaves some glue left, go get the 3M's adhesive&wax remover from PepBoys.
Old Mar 15, 2004 | 04:48 PM
Blue Batmobile's Avatar
Blue Batmobile
Inventor
Blue Batmobile
Let the car sit in the sun for awhile to soften the vinyl. Take a needle and lift one end, and slowly peel. Ort use a hair dryer to heat it up. I've never had any problems with alot of residue left behind. The key is to peel it very slowly so the residue stays on the vinyl. Any residue left use adhesive remover, citrus based.
Bat™
Old Mar 15, 2004 | 07:06 PM
MCopare's Avatar
MCopare
thanks guys.
Old Mar 16, 2004 | 05:51 PM
Dr Bonz's Avatar
Dr Bonz
Charter Member #19
So does he get a third strike for removing his vinyl overlays???
Old Mar 16, 2004 | 09:01 PM
MCopare's Avatar
MCopare
not sure what my strikes were for...but i loved the vinyls...i just did a poor job of putting them on Dr. Bonz. I wish there was some way to get them removed....
Old Mar 16, 2004 | 09:03 PM
MCopare's Avatar
MCopare
the strikes that is...
Old Mar 16, 2004 | 09:41 PM
Blue Batmobile
Inventor
Blue Batmobile
Bat
Old Mar 17, 2004 | 04:37 AM
Hraesvelg's Avatar
Hraesvelg
Got Uranium?
So what happened with your install? Were they easy to put on correctly?
Blue Batmobile
Jul 12, 2004 12:55 PM
Blue Batmobile
Jun 5, 2004 03:17 PM
Blue Batmobile
Feb 8, 2004 06:31 PM
Blue Batmobile
Jan 24, 2004 09:52 PM
Blue Batmobile
Jan 24, 2004 08:58 AM
