Left Foot Rest - Loose?
Old May 24, 2004 | 03:05 PM
jerryv's Avatar
jerryv
Question Left Foot Rest - Loose?
I have had my automatic Touring for a couple months. The only thing I have noticed is that the left foot rest seems loose. Seems like it is not secured at the top of the rest giving it some movement.
For those with an automatic how tightly is the left foot rest secured?
Thanks!
Old May 24, 2004 | 03:07 PM
BENJ-AMG's Avatar
BENJ-AMG
Mine feels loose too. Haven't examined it closely but I bet there is just a screw that needs tightening.
Old May 24, 2004 | 03:49 PM
jerryv's Avatar
jerryv
I just got done taking it apart. I appears that there are two large plastic things that are supposed to tighten around the two screws sticking up from the car body. The one on the top does not grab hold of the screw and pops up. Therefore the top of the foot rest is not secured. Given it is the plastic "crap" thing that is not holding the screw it will need to be fixed at the dealer.
/Jerry
Old May 24, 2004 | 04:38 PM
AZZGUY's Avatar
AZZGUY
Us MT guys dont have that problem - foot on cluctch very much!!
I do use it though -never had that in another auto.
Old May 24, 2004 | 04:45 PM
nitrousoxidex's Avatar
nitrousoxidex
On my base, its this crappy black piece of plastic. If I give it a firm pull, it just pops right off.
Old May 24, 2004 | 04:52 PM
DMONTE's Avatar
DMONTE
Yeah I had mine replaced last week under warranty, the whole thing is a one-shot plastic push on apparatus. It feels tight again for now
Old May 24, 2004 | 06:10 PM
n8vz's Avatar
n8vz
same problem here, it is just a big piece of plastic wedge and is clipped on. Seems like everything on Nissan are secured by plastic snap on fasteners.
Old May 24, 2004 | 09:14 PM
elyliu's Avatar
elyliu
i had that problem on my manula from day one....
at first i tried to tighten those screw on top. DO NOT DO THAT! They are just there for decoration. Not functional.
I pulled the whole thing off. Played w/ the clips on the back a bit. Twisting it and stuff. And somehow got it back on.
It's fine now. Just take it off and twist around the clip thingies.
Old May 25, 2004 | 07:23 AM
Jun's Avatar
Jun
i've tried twisting it, at every single position, it will not clip back on. This is dangerous, because sometimes the shoe can get caught and imagine if the foot rest comes off and gets stuck under the brake pedal.
It was loose because I had pulled it off to reach the fuse box (which, by the way, i think it wasn't necessary to do so). And once it was out, it wasn't going in as before. So i guess the next thing to do is buy another pedal from courtesy parts ($17.00) and get it replaced (I have a base, i had to put the aluminum pedals after, so going to the dealer is out of the question).
Old May 25, 2004 | 08:45 PM
elyliu's Avatar
elyliu
i was thinking the same way. "Great, I pulled this thing off, now I can't put it back on."
try to stick in back on some more. Line it up w/ the bolts sticking out and push straight in. Took me a while....
Old Jun 15, 2009 | 07:43 PM
ThundrA's Avatar
ThundrA
I drive a manual car, and I also have that problem.
At first I thought I didn't push the top hard enough, so I started kicking it, but that doesn't help at all.
Weird thing is that, the bottom part seems to be secured. And as you know, once it's secured, you can't pop it off. So now I'm stucked because I can't take the dead pedal off. I can simply pop the top and turn it clockwise 90* but I still can't reach the bottom screw.
I don't want to take it to the dealership, they told me that base model didn't come with those pedals, so it's not under warranty. If I want them to fix it, the labor fees will be around $200, because they might have to drill holes etc...
Someone help me with this.
Old Jun 15, 2009 | 08:29 PM
weblair24's Avatar
weblair24
I have a base model, and mine did come with a (loose) footrest.
Old Jun 16, 2009 | 10:07 AM
Done Deal DR's Avatar
Done Deal DR
There was some sort of a DIY a while back where guys were taking it off, wrapping the pegs in electrical take IIRC and then pushing it back in. I have yet to try this but likely will soon.
Old Jun 16, 2009 | 05:46 PM
JonnyRod's Avatar
JonnyRod
Mine was loose...I ended up pulling it off and putting a mild epoxy on the pegs and pushed it back in...nice and solid now
Old Jun 16, 2009 | 05:48 PM
Hraesvelg's Avatar
Hraesvelg
Got Uranium?
A noob that searches... You win all my internets.
wanderingstuden
Jan 28, 2016 07:03 PM
