Problems with borla
Old Aug 10, 2004 | 08:19 AM
Reggi914's Avatar
Reggi914
Default Problems with borla
For borla TD owner, did you guys have any problems with the exhaust? I heard that because there are over a dozen pieces, the exhaust had some problems and that the tips are very hard to align. Also, how does the borla change the sound of the Z? Does it still have that Z sound?
Old Aug 10, 2004 | 08:49 AM
BrImSt0ne's Avatar
BrImSt0ne
had mine installed 1yr ago by a muffler shop. no problems at all. the sound is almost the same as stock but deeper.
Old Aug 10, 2004 | 08:58 AM
ChadK's Avatar
ChadK
I did my install a couple of weeks ago along with high flow cats. A friend and I did it on jack stands in about 3 hours, it went very smooth. Just put everything together loose without tightening down the clamps, once everything is in place align it and tighten everything down. The sound still has the Z note to it it is just a little bit more aggresive.
Old Aug 10, 2004 | 09:47 AM
zh.guitar's Avatar
zh.guitar
Leave your mark!
Had mine installed 1 year ago with no problems. Had a pro install it.
Sounds like stock with deeper note and opens up about 4000 rpm where it is louder than stock.
love it....
Old Aug 10, 2004 | 01:18 PM
Leh GSC's Avatar
Leh GSC
you wont have any trouble with that exhuast. its good stuff.
Old Aug 10, 2004 | 03:06 PM
Reggi914's Avatar
Reggi914
What about at idle, is it a bit louder? I would like the z to be a bit louder at idle.
Old Aug 10, 2004 | 03:29 PM
ZpEeDRaCeR's Avatar
ZpEeDRaCeR
for all of you with it is it a good mod for the money? I noticed it is one of the least expensive, can you feel the difference in performance really?
Old Aug 10, 2004 | 05:32 PM
DavesZ#3's Avatar
DavesZ#3
It's not likely that you'll "feel" a 5 HP difference. Get it (or any other exhaust) for the sound and looks, not because it's going to make a couple of HP.
Old Aug 10, 2004 | 05:53 PM
Reggi914's Avatar
Reggi914
So how does the borla sound compare to the nismo exhaust at idle, cruising, and WOT.
Uriyo_
Sep 8, 2021 08:46 AM
TDPrank
Sep 28, 2015 06:29 AM
