Emblem removal
Old Sep 1, 2004 | 12:22 PM
Reggi914's Avatar
Reggi914
Default Emblem removal
Can someone help me out and tell me how to remove the front and rear emblems please. Thanks
Old Sep 1, 2004 | 01:46 PM
juhko's Avatar
juhko
Default Do a search!
I debagded mine by doing the following:
Slide dental floss under the badge and work it through and under as best as possible until you can pull the badge up. (there will be two holes underneath that may look ugly to you)
Heat the residual glue residue with a hair dryer for a few minutes and it should come off pretty easily (if not, get some Goo Gone).
Old Sep 1, 2004 | 05:19 PM
Reggi914's Avatar
Reggi914
thanks, i will try that.
Old Sep 1, 2004 | 05:27 PM
SEzzz's Avatar
SEzzz
what did you do with the holes?
Old Sep 1, 2004 | 05:45 PM
Reggi914's Avatar
Reggi914
i tried the floss on the rear emblem and it doeset work. What about the front emblem, how do you get that one off?
Old Sep 1, 2004 | 06:26 PM
sal1's Avatar
sal1
I also tried the dental floss trick and couldn't get it to work either. I put a couple of strips of masking tape on top of each other to the side of the emblem to protect the paint and I gently used a small bladed screw driver with one hand, and a hair drier with the other one. Once it start to come off, grab it and pull while still applying heat On the rear emblem I masked around the emblem to make sure it went back in the same place (even though the new emblem is a little bigger).
Old Sep 1, 2004 | 07:39 PM
alininger2001's Avatar
alininger2001
Dental floss and a hairdryer should do it, fishing lin works good too. Not as gentle as floss, but stronger. Getting it hot with the hairdryer is a must.
Old Sep 1, 2004 | 08:32 PM
Reggi914's Avatar
Reggi914
How do you get the floss under the front bumper? Its molded into the bumper. Does the rear embles have holes under it (2003 touring)?
Old Sep 1, 2004 | 09:00 PM
mgl's Avatar
mgl
there is a little space between the emblem and the bumper. so the floss will fit. but i just used a screw driver and pryed it off. (i didn't care about the scratches as i shaved the emblem anyways)
and i believe all z's have the holes underneath the rear emblem except for roadsters. good luck.
Old Sep 2, 2004 | 05:07 AM
Reggi914's Avatar
Reggi914
who sells that goo off stuff?
Old Sep 2, 2004 | 05:20 AM
KShep's Avatar
KShep
Pretty sure I saw some at Lowe's. Sounds like you are having fun.
Try a pair of pliers and a blow torch, that should do it...
Old Sep 2, 2004 | 11:44 AM
juhko's Avatar
juhko
Definitely don't blow torch it!
Yes, the holes suck. I haven't had them filled as I don't feel like getting them filled and having the whole body panel painted.
Old Sep 2, 2004 | 11:55 AM
Reggi914's Avatar
Reggi914
I want to take off the emblem, not the bumper!
sales@czp
Sep 23, 2019 03:30 PM
3vilbunny
Jul 18, 2017 05:10 PM
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
Depravity
Oct 1, 2015 04:49 PM
Extreme Dimensions
Southern California
Sep 24, 2015 03:35 PM
