Shorty Antenna
Old Sep 7, 2004 | 09:58 AM
lunartick13's Avatar
lunartick13
Default Shorty Antenna
I removed the OEM antenna and replaced it with an after market one, Mfged in Germany, the antenna looks great but I lost about 80% of my radio reception. Any one out there who knows what antenna to buy that will keep the same reception and still look good?
Sorry if this has been posted before.
Thanks,
Old Sep 7, 2004 | 10:10 AM
zectasy's Avatar
zectasy
i have the s2000 antenna i got straight from honda...it fits good but i never listen to my radio so i couldnt tell you how the reception is
Old Sep 7, 2004 | 10:17 AM
myz8a4re's Avatar
myz8a4re
lunartick13 we probably purchased the same antenna, i had this german one as well another billet shorty antenna & both reduced reception greatly. i currently have my factory one back on.......
zectasy, would you turn your radio on & flip through a couple stations to see how the reception comes in with the s2000 antenna? just a flip through next time you drive the car. we would greatly appreciate it.......
thanx,
-justin
Old Sep 7, 2004 | 10:43 AM
asatyss's Avatar
asatyss
I just got the S2000 antenna last week and have not noticed any drop off in the radio signal. I listen to the radio on and off, but enough to tell if it made a difference.
It was $26 with tax straight from the Honda dealership. It's worth it.
Old Sep 7, 2004 | 10:47 AM
myz8a4re's Avatar
myz8a4re
if you didnt notice a difference than this is a good thing. the difference in the antennas mentioned above is very obvious. almost as bad as running no antenna at all......thanx for the info im going to run by honda this afternoon!
-justin
Old Sep 7, 2004 | 12:18 PM
CC 350Z's Avatar
CC 350Z
S2000 is as good as stock.
Old Sep 7, 2004 | 12:30 PM
zectasy's Avatar
zectasy
well theres your proof but i will double check how the radio is when i get my car back...its in the shop
Old Sep 7, 2004 | 12:49 PM
jim-n-cathy's Avatar
jim-n-cathy
asatyss, one point about the S2000 antenna I've read on other threads is that the base does not match up exactly with the Z mount. Just a slight difference. Did you find that to be the case? -- Jim
Old Sep 7, 2004 | 06:13 PM
lunartick13
From what I see so far The S2000 seems to be the way to go, I will try it even if my Z will be .000009% Honda. I will do the mod and post my results.
Thanks you all!!.
One more thing for those who have the antenna installed, how is the fit? does it line up like it was OEM?
Old Sep 7, 2004 | 06:17 PM
myz8a4re's Avatar
myz8a4re
im still kinda bummed they dont make a billet shorty that works good......the black shorty will suffice for now.........
-justin
Old Sep 7, 2004 | 06:44 PM
CC 350Z's Avatar
CC 350Z
Fitment is pretty good... just a bit off but not bad at all
Old Sep 7, 2004 | 10:53 PM
mgl's Avatar
mgl
i have the s2k antenna and it works fine and looks better than the oem one.
it is true that the base is slightly larger, but it not that noticable.
if you want to try another antenna, go to is300.net and theres a guy there who sells shorty antennas for $20. he guarantees reception, quality, etc...
Old Sep 7, 2004 | 11:53 PM
apharmdb's Avatar
apharmdb
I'm using the JDM IS300 antennae. While it works it definitely is not as good as stock. Fit is pretty cool though.
Old Sep 8, 2004 | 05:02 AM
Tekwon-V's Avatar
Tekwon-V
another vouch for the s2k antenna.
reception is the same as nissan oe antenna, imo. the base doesnt look flush with the mount but not enough stick your tongue out.
Old Sep 8, 2004 | 05:16 AM
SungNamZ's Avatar
SungNamZ
When ALL else fails, try this one from: www.jscspeed .com EVO 8 "Perrin Shorty Antenna". I like the fit, looks and reception.
Old Sep 8, 2004 | 01:43 PM
myz8a4re's Avatar
myz8a4re
i just got my s2k antenna at my local honda dealership today. it was only $19.76, cant beat that! the reception is all as good as the OEM antenna. the bulkier base is nothing to complain about. after seeing statements made about it being bigger i pictured somthing totally different. were talking about a 1/32" difference, looks totally normal to me......
-justin
Old Sep 8, 2004 | 05:40 PM
basam350z's Avatar
basam350z
any have a pic?
Old Sep 9, 2004 | 01:43 PM
Road Warrior's Avatar
Road Warrior
how much...link is down at the moment...thanks
Old Sep 9, 2004 | 02:39 PM
SungNamZ's Avatar
SungNamZ
In December it was $27.00 + S/H. Let me pass along a couple of numbers: 717-397-4637 or 717-295-0249 (fax) Try also to send an email to: Chris@JSCSpeed.com
reno56
Interior
17
Nov 20, 2015 05:21 PM
bcoffee20
Nov 19, 2015 06:39 PM
cashmoney03
Sep 27, 2015 05:24 PM
MTL350z
May 2, 2003 10:09 AM
john350Z
Mar 20, 2003 06:55 PM
