what kinda light weight batteries are good?
Old Sep 20, 2004 | 06:10 PM
sifuK's Avatar
sifuK
Default what kinda light weight batteries are good?
please tell me the pro and con with these batteries.
http://www.brailleauto.com/braille_n...ht_battery.htm
http://forums.vwvortex.com/zerothread?id=1538593
http://surplusev.com/
http://www.dmstech.co.uk/hawker.htm
Old Sep 21, 2004 | 09:35 AM
sifuK's Avatar
sifuK
hello?
Old Sep 21, 2004 | 10:02 AM
mgl's Avatar
mgl
i too lazy to read all your links.... but optima is good.
Old Sep 21, 2004 | 10:39 AM
sifuK's Avatar
sifuK
sorry "pros and cons"
I sound like a FOB. haha
Old Sep 21, 2004 | 11:35 AM
GY-Z's Avatar
GY-Z
whats ur definition of "good"?
light enough? or strong?
Old Sep 21, 2004 | 12:57 PM
sifuK's Avatar
sifuK
over all
price
weight
power
durabilty
quality
etc......
Old Sep 21, 2004 | 02:13 PM
dnguyent's Avatar
dnguyent
I just installed my Hawker Odyssey PC680 w/metal jacket:
Price: Approx $100 including brass SAE terminals
Weight: Approx 15.5lbs
Power: Enough to crank the engine, but not enough to run accessories with engine off. Don't know how well it will handle the colder winters, so we'll see.
Durability: Not known...I just got mine.
Quality: Looks top notch.
For the time being, I have to use a block of wood to prop up the battery so that the hold-down could keep the battery secure. It looks really guetto, but it works. I'll probably try fabricating a custom hold-down similar to Vlad's.
Old Sep 23, 2004 | 08:14 AM
MySunset350Z's Avatar
MySunset350Z
same here. just installed the odyssey pc680. no metal jacket. weight is 14.7lbs. i think we could of gotten aways with a pc535 which only weights 12lbs. but the cranking power is a lot lower.
so far so good, but u really wont be able to run anything with the car off. it'll discharge completely within 18minutes. that and i noticed the battery gauge is never above 12.8v and does dip as low as 12v on cold starts. the stock battery was at a consistant 13.2v.
bracket was pretty easy to make for the battery, just time consuming.
Old Sep 23, 2004 | 10:26 AM
MY350Z.COM's Avatar
I just ordered a Odyssey PC680MJ on eBay
Old Sep 23, 2004 | 12:18 PM
MySunset350Z
thats where i got mine from.
just a quick correction. i said the stock battery voltage was 13.2v when the car is on, but the reading was actually 14.2v.
Old Sep 23, 2004 | 02:03 PM
sifuK's Avatar
sifuK
thanks for the info
can u guys compare it with the stock battery pros and cons
Old Sep 23, 2004 | 02:07 PM
sifuK's Avatar
sifuK
how long does the stock battery last while the car is off?
Old Sep 23, 2004 | 10:43 PM
MySunset350Z
the odyssey battery has less cranking power then the stock battery, less cold cranking amps then the stock battery, it can be mounted in any way except for upside down and weights about 20-25lbs less then the stock battery. then again, you dont need all that added cranking power. its "surplus".
i've ran the cd player (blows system) for about 3 hours before while working on my car without draining the stock battery. just to give you an idea.
this battery is really a harley battery. its about 1/3 the size of our stock battery, but will meet specs for our car.
Dr.Paulyy
Jul 29, 2019 07:45 AM
tm9293
North East Marketplace
13
Oct 17, 2015 09:14 PM
Dymsi
Sep 29, 2015 11:32 AM
samansharif
Sep 25, 2015 12:31 PM
