How to get at the rear turn signal bulbs?
Old Oct 9, 2004 | 03:00 PM
Sponge's Avatar
Sponge
Default How to get at the rear turn signal bulbs?
Got some LED bulbs and want to replace the stock ones. Took a look at the rear plastics and they seen not to go low enuf to get at the bulbs. Don't see a way to get at them from the outside under the car.
So...how do you get at them?
Old Oct 9, 2004 | 03:17 PM
Street Visionz, Inc.'s Avatar
First look on top of each taillight and you will see 3 caps covering 3 bolts. pop up the caps with a flat screwdriver and you will see 3 bolts, I can't rememer if they were 8 or 10mm each but unbolt them. then pop out the taillight, it will require some force since there are clips holding it in. pull out the tailight and you will see the bulb down within the bumper. twist and pull out the bulb out of the socket and there you go. hope this helps.
-andrew
Old Oct 12, 2004 | 01:49 PM
t32gzz's Avatar
t32gzz
The socket is 10mm. Pull the taillight diagonally away from the side of the car. The clips are diagonal like this /.
Old Oct 12, 2004 | 01:54 PM
Sponge's Avatar
Sponge
Cool thx guys. Bulbs are in and look great. Very easy to do now that I know what to do.
Old Oct 13, 2004 | 02:21 PM
Strife350z's Avatar
Strife350z
are the LED bulbs bright enough?
I heard that they are much dimmer than stock
Old Oct 15, 2004 | 08:33 PM
juhko's Avatar
juhko
They are, which makes me wonder how liable one is in an accident if their signal is too dim, would the cop make that judgement?
Anyhow, if you want LEDs, I'd go with the one Ares makes (http://www.rasecreations.com)
Old Oct 15, 2004 | 09:34 PM
Sponge's Avatar
Sponge
Yeah,
I have Ares 7440 LED set in the front. I like the output, bright enough for me. Plus I like the lack of orange in the headlamp. Now if I can just find some clear reflector strips and someone to split my headlamps for me...
Pleask
Dec 21, 2021 03:17 PM
Uriyo_
Sep 8, 2021 08:46 AM
