How To: Fiberglass
Old Oct 13, 2004 | 10:34 AM
ExtaZ33's Avatar
ExtaZ33
Default How To: Fiberglass
I was wondering if there was a how-to manual or some kind of online instruction. I want to make a few things out of fiberglass and then have them painted to match my exterior, but I don't even know where to begin. I don't really have anyone to show me, so is there anyone that knows where I can find some free help online or maybe a book on it?
Old Oct 13, 2004 | 11:35 AM
ares's Avatar
ares
Veteran
no links; but generally you take a negative mold of what you want to make. then wax it or make it from styrofoam/wax something that can be cracked away.
now lay sheets of fiberglass onto it and paint it with epoxy. add a layer of fiberglass untill it reaches your ideal thickness.
last step, sand the freakin hell out of it.
carbon fiber is the same process I beleive; but only 1 layer to keep the weave. fake carbon fiber is 1 layer of carbon fiber; and then multiple layers of fiberglass behind it for strength.
you can buy it as 1 mix; its basicly a very thick epoxy filled with glass fibers for some strength. I find this to be rather lumpy though.
Old Oct 13, 2004 | 12:40 PM
Moroccan_Mole's Avatar
Moroccan_Mole
google is your friend.
ares sorta has it ... but not really.
you have resin (looks like tree sap) + a hardener. then you have sheets of fiberglass.
you mix the hardener with the resin ... it should be workable for about 15 mins.
you paint the resin on, lay down fiberglass, and then 'blotch' more resin over the fiberglass so that it's completely saturated. depending on what you're doing 2-3 layers should be enough.
Old Oct 13, 2004 | 01:29 PM
teh215's Avatar
teh215
My neighbor molded speakers into the door panels of his WRX over the summer. He was out back for weeks sanding the panels, adding filler, sanding the panels ... They turned out really nice but it took alot of elbow grease to get the contours smooth. I have never done any fiberglass work before but the process looked very straight forward.
Old Oct 13, 2004 | 01:58 PM
Moroccan_Mole
it's very easy to do.
my first time trying it i repaired my air walker bumper/sides after bieng hit by some road debris. it took 2 days to repair the bumper and sides including all the sanding and most of the major body work. - most of the time was spent waiting for the stuff to dry!
one of the most important things (especially if working on the interior of the car) is to have a respirator otherwise just a particle mask will work.
i have pics on my camera of the process ... but i left my camera somehere and can't find it!!
Extreme Dimensions
Southern California
Sep 24, 2015 03:35 PM
dcains
Sep 21, 2015 09:28 AM
Encore
Audio Builds
69
Sep 29, 2008 05:50 PM
bastard
Mar 11, 2003 10:06 PM
