nismo shift knob question
Old Oct 17, 2004 | 12:35 AM
ssc's Avatar
ssc
Default nismo shift **** question
can anybody tell me if the nismo gt titanium shift **** has plastic threading inside or is it metal. cuz i read someone on this forum had a non-gt one and stripped the inside which was plastic. i like spirited driving and i don't want to spend like $140 on a piece that's gonna end up in the trash.
Old Oct 17, 2004 | 01:49 AM
Z-INCOGNITO's Avatar
Z-INCOGNITO
i believe it is plastic...
Old Oct 17, 2004 | 08:53 AM
lowrider's Avatar
lowrider
Not positive, but I think it's plastic also. That's because it's not really threaded, but it's soft enough for you to put it on the shift rod, and the rod will act like a tap, and thread it. It's pretty sturdy though. I have the leaher **** (I like leather) and removed it once to put on the Home Depot Toilet Washer Finisher, and it's as tight as the day I bought it. Can't post pics anymore.
Lou
Old Oct 20, 2004 | 03:38 PM
35ounces's Avatar
35ounces
03 CS Track 6MT
not plastic. Its metal. At least mine is.
Old Oct 20, 2004 | 03:47 PM
ssc's Avatar
ssc
cool, thanks for the info. i guess i'll order it and see for myself. by the way, do you know where i can get the finisher for the ****. i think i read somewhere i can use a $2 toilet washer.
Old Oct 20, 2004 | 06:30 PM
ZIABLO's Avatar
ZIABLO
I am Batman
my nismo TI (non-GT) shift **** threading is plastic. and it's STRIPPED! (with the rogue engineering short shifter)
after discovering this, i tried to put it on the stock shifter and it fit fine!
but to keep it on the RE short shifter i took out the spacer btwn the shifter and **** and tightened that sucker back on. and i think i created new threads. it's on TIGHT now!
if you need more coherent sentences or want to know more, pm me.
Old Oct 21, 2004 | 12:38 AM
DeeZee's Avatar
DeeZee
i have the same setup as EnthuZiastDrive, and mine is on VERY tight. i have had no problems so far. 10,000 miles id guess???
Old Oct 21, 2004 | 10:49 PM
MY350Z.COM's Avatar
Ditto, same setup here Rogue + NISMO Ti (non-GT), no slip, all grip
sherm
Apr 11, 2020 05:21 PM
issyz
Jul 2, 2017 03:04 PM
nanotech
Oct 2, 2015 05:02 AM
Alexreyes
Sep 30, 2015 11:30 PM
