Urethane and FRP???
Old Oct 20, 2004 | 08:43 PM
lemonjihwan's Avatar
lemonjihwan
Default Urethane and FRP???
I was just wondering while i was looking for front lip...
What's the difference between Urethane and FRP??
what the heck is FRP???
and which one is better???
Thanks.
Old Oct 20, 2004 | 10:40 PM
MY350Z.COM's Avatar
FRP = Fiberglass Reinforced Plastic, usually the cheaper kits, requires prepwork, can be extensive.
Urethane is better because it can be more flexible and take hits, requires very minimal prepwork, usually more expensive. Urethane kits are harder to find nowadays.
However a new material called PFRP (Pultruded fibre reinforced plastic) can be comparable to urethane while costing less than urethane.
Victor
Old Oct 21, 2004 | 06:42 AM
insaneamine's Avatar
insaneamine
Inventor
Z-Xtreme.com
What he said...
and, another thing to note about urethane is that becuase it is more flexible, impacts tend to make the paint chip and crack easier.
Old Oct 21, 2004 | 08:57 AM
lemonjihwan
what do people usually get? when they are trying to get a front lip? because im looking at Veilside V-1 front Lip...
probably urethane is the better way right?
OH!! one other thing for Z-Extreme!!
what's difference between 5wire ,6 wire, 7 wire grounding kit??
and i have 6spd touring Z...
thanks!
Old Oct 21, 2004 | 10:33 AM
Jergens's Avatar
Jergens
I wish Espirit would make their front in Urethane. I know I am going to crack the sucker around Tampa, no way around it. The only urethane kit that I have seen that is a full front is the Stillen one, and I am not thrilled with it, although maybe I will be if I see it in a shot other than the one on Stillens website.
~Josh
Old Oct 21, 2004 | 11:05 AM
kzshin's Avatar
kzshin
it's an mis-undertanding that poly urethan (PU) is better than fiber glass kit. It really depends on who makes them. Usually, the fiber glass kit that we got in the US are bad qualities, don't matter how good the ad said. And that's why US made FRP kits are usually cheaper. PU is very durable, but weight's more, Fiber glass is alot lighter.
If you pay attention, most of the bodykits manufacutures from Japan dont even make PU kit. They have Fiber glass, PFRP, or Carbon or Kevlar. And their Fiber glass kit's finishing and qualities alot differnent than those Knock off NISMO kit, or kit's that you usually see on HONDAs.
Regarind FRP is easier to break than urthane, that's not exactly ture. IF you hit some thing both going to break, period. However FRP is repairable, but you can't repair PU.
Another thing is, Japanese body kit are alot more expensive because the qualities. So what you pay is what you got.
Old Oct 21, 2004 | 05:35 PM
lemonjihwan
then what is our factory bumper made by?
Old Oct 21, 2004 | 11:38 PM
kzshin's Avatar
kzshin
usually ABS plastic
Old Oct 23, 2004 | 02:45 PM
Jergens's Avatar
Jergens
I dunno my Urethane front on my BMW took some REALLY nasty whacks and never cracked. Fiberglass has no flex , Urethane does. I dunno I haven't seen any fiberglass that has give without cracking/peeling. That doesn't mean it isn't out there, but from what I know of the material, I don't think it is possible for it to flex as much as Urethane.
Josh
EnjukuRacing
Drivetrain
Sep 14, 2015 11:15 AM
Chebosto
Feb 27, 2008 11:47 AM
ppak3
Feb 14, 2004 10:34 PM
3fifty
Dec 8, 2003 02:04 AM
MATIX
Aug 25, 2003 12:15 AM
