Can I use normal 194 LED bulbs in my parking lights?
For the parking light bulbs, all you have to do is pull back the pastic wheel cover, turn the wheel to the right when doing the left side and vice versa for easier access.
I have the load equalizers installed to prevent the lights from blinking retarded. It was no big deal, you don't have to "cut" the stock wires, just use those wire spice connectors that they supply with it.
I received an e-mail back from autolumination. They are the same diameter as stock (3/4"). I orderd two 7443's for the taillights and two 194's for the parking lights.
I decided to go with red LED's in the back because that seems to be what everybody else is doing, plus they are cheaper, $9.99 vs $11.99 for clear.
Pretty inexpensive so I'm interested to see the quality.
Second thought, you don't need them for the 350z, but if you have a BMW or a car that detects burnt out taillights, you would need a load stabilizer (resistor) to get rid of the message.
Originally posted by maxpowers
No just for turn signals.
