have u put the front license plate on?
Old Nov 1, 2004 | 10:30 AM
desiguy's Avatar
desiguy
Default have u put the front license plate on?
Hey Guys,
I'm pretty new to this forum and the Z experience. I picked up my LeMans Sunset Enth Z this weekend and insisted that the dealer not put the front plates on. I'm in NY and it is required by law to have the front plate on. For those of you in NY (or other states w/ similiar laws), what have you done? I've heard of people putting the frame in the grill. How is that done? I drive in the boroughs every now and then, and there are always cops around, and I really don't want to be funding NYC's budget deficit...so any opinions, would be appreciated!
Old Nov 1, 2004 | 10:51 AM
ZZZealous007's Avatar
ZZZealous007
you can buy the strictly Z license plate adapter. or you can make one... someone on the forum posted a DIYer a while back.
Old Nov 1, 2004 | 10:54 AM
desiguy's Avatar
desiguy
thanks the reply, where can i buy that?
Old Nov 1, 2004 | 11:27 AM
CatastrophZZ's Avatar
CatastrophZZ
or you can just use zip ties at no cost(if you already have them). use black ones if you dont want to look ghetto, and just snip the excess. i had mine in the windshield with 2 suction cups(supposingly rear[with hooks]).
Old Nov 1, 2004 | 01:04 PM
mofoz's Avatar
mofoz
the link appears on top of this as one of the banners. i think it might be strictlyz.com ? not sure off hand, i just dont have mine on.
Old Nov 1, 2004 | 01:43 PM
kamz's Avatar
kamz
I'm in CA and we are required to have the front plate as well but I chose not to put mine up. I've driven by many cops and I'm sure they notice the missing plate but none has been an #ss and given me a ticket. I figure it's a fix it ticket and I'll consider putting the Z-brackets if I do get pulled over... knock on wood...
Old Nov 1, 2004 | 01:49 PM
ares's Avatar
ares
Veteran
move to Georgia woot no front plate.
Old Nov 1, 2004 | 02:45 PM
LanceG33's Avatar
LanceG33
Default front plate
I had mine mounted on although not by the dealer . . . my mounting bracket was in the cargo net when I took delivery. So, last week when I had my Nismo wing put on I did the following:
My Body shop painted the mounting bracket, my metal license plate frame and the frame screw caps in silverstone to match the car - it looks super clean and flawless.
I thought about going without, but with my 14% tint I was concerned about getting a double whammy fix-it ticket.
I'm pleased with how it looks - will post pix when I get some.
Old Nov 1, 2004 | 04:36 PM
AudioPat's Avatar
AudioPat
Up Front Enterprises
Desiguy
You might want to check out my 'Zee-Bracket'
You can pick one up from Courtesy Nissan
Just click on the link below for more info
Old Nov 1, 2004 | 05:20 PM
desiguy's Avatar
desiguy
thx guys, i appreciate the help!
Old Nov 3, 2004 | 12:53 AM
rouxeny's Avatar
rouxeny
I finally installed my Zee-Bracket after buying it from Courtesy a few months ago.
Installation is easy, and the plate is secure.
Pat, if you want a pic of a car with a Hawaii plate and your bracket, I'll be glad to send one to you.
Old Nov 3, 2004 | 07:54 AM
AudioPat's Avatar
AudioPat
Andrew...thanks for the support
Send the pic to me at
UFE2003@aol.com
Old Nov 4, 2004 | 06:58 PM
basam350z's Avatar
basam350z
Cops can Kiss my hairy A$$, I have never see a Corvette with a front plate on and they don't get bugged. They can pull me over all they want, I'll just put something temporary to get the ticket dropped and take it right back off.
But I found out two things in my life about this:
1) They only pull over hoptez for this
2) They'll only pull you over for this if you are a cruising the "strip".
Sports cars rarely get hassled by this law in WI.
Old Nov 5, 2004 | 05:02 AM
desiguy's Avatar
desiguy
hey,
i went thru the upfront link and the courtesy nissan link doesn't work....any other link?
Originally posted by AudioPat
Desiguy
Old Nov 5, 2004 | 01:19 PM
Randall Patters's Avatar
Randall Patters
Default Strickly Z style
Bracket schmackett. this is the only way to go, so easy to take off for shows and meets!
Old Nov 5, 2004 | 01:22 PM
Randall Patters
Default here's a link
linky. http://www.strictlyz.com/customer/pr...d852b9e0141986
Old Nov 5, 2004 | 02:20 PM
AudioPat's Avatar
AudioPat
Try This
http://www.courtesyparts.com/Merchan..._Code=ZEE-BRCT
Old Nov 5, 2004 | 09:12 PM
mgl's Avatar
mgl
the strictly z ones are pretty good!
Old Nov 5, 2004 | 09:24 PM
apharmdb's Avatar
apharmdb
Bought the Strictly Z one also. Quick and easy to install and it's pretty clean (as clean can get with a front plate )
Old Nov 6, 2004 | 12:52 PM
350fanatic's Avatar
350fanatic
putting on your windshield? thats the same as not puttin it on, ive got a fixing ticket for placin my license plate there.
ill keep it off till them ******** give me a fixin ticket, who says theres a fine for this? there is no fine!
when you get nailed you just have to fix it within a certain amount of time
