Feedback & Suggestions for Our Forum This is NOT a place to ask car/modification questions!
For posting feedback, suggestions or comments regarding our My350Z.com forum.
VDC Light, SLIP, and Check Engine Light Problem
Old Mar 30, 2019 | 04:37 PM
Javier6215's Avatar
Javier6215
Default VDC Light, SLIP, and Check Engine Light Problem
I was changing my O2 sensor and once everything was said and done I turned on my car and the check engine light came on along with VDC and SLIP light and it wasn’t letting accelerate above 3k rpms. I put the old one back in and it’s still the same I don’t know what I did wrong. I need help asap
Old Mar 31, 2019 | 08:31 PM
Chihuahuamaster's Avatar
Chihuahuamaster
The car is basically going into limp mode because of an issue. You need to back-track what you did/ took apart, and make sure everything is installed correctly. Such as the plugs on all of the sensors, if you had to remove any.
Try to disconnect the battery for an hour or so, and then see if the issue persists. Also, it would help to read the codes if any from the CEL.
Old Apr 1, 2019 | 05:59 AM
travlee's Avatar
travlee
Master
its probably because you posted in the wrong section.... this subforum is for suggestions to make the forum better. it clearly states that it is not for asking car questions
Old Apr 1, 2019 | 03:12 PM
Javier6215's Avatar
Javier6215
Yea it ended up being my mass air flow sensor thanks for the help
eliopulos_2jz
Jul 25, 2014 05:05 AM
ccchaorule
Aug 16, 2012 12:12 PM
bleunetizen
Tuning
Jun 20, 2007 06:01 PM
Brando222
Oct 24, 2005 10:23 AM
