Oil pressure question with vortech
Old Nov 27, 2004 | 10:11 AM
freezeg35's Avatar
freezeg35
Default Oil pressure question with vortech
So my car has been sitting for the last 4 months, unfortunately due to bad weather and road construction on my main path to work. After the vortech was installed the car idled at about 20 psi and would go to 100 under full load/boost. I started the car today, actually had to jump start it in my garage, and it idled at about 10 -15 psi. Now all my other idiot lights are fine, egt is fine, seems to warm up and idle fine. When i rev it, the gauge kind of spikes and flutters a bit. Im a little paranoid that i have no oil pressure, like maybe when they drilled the pan a shaving got in to the oil pump? I know the put in the new oil after the install and i saw the car on the hoist and it had a orange sealant on the pan, so im assuming the did the clean drill and tap. Oh and before i forget, probably the most important thing, its an autometer oil gauge i have. I know they are cheap but you would think it would not crap out so soon.
PS: are our batteries that crappy. I ran the car for 10 min. Shut it off and it was dead again.
TIA
Old Nov 27, 2004 | 10:27 AM
booger's Avatar
booger
Did you warm the car up all the way ?....drive it for 30 minutes or so ? That would give the time for oil to get hot and every thing to get back to where it was before you stored it for 4 months . Your battery is more than likely shot . You need to take it out if you store it for that long
Old Nov 27, 2004 | 10:55 AM
freezeg35's Avatar
freezeg35
Boog, do you think im being paranoid about the pressure. My oil idiot light has not indicated any prob, and the car temp. is right in the middle where it should be. Me personally, im thinking its the autometer quality showing.
Old Nov 27, 2004 | 03:43 PM
booger's Avatar
booger
I wouldnt worry about it , Just keep an eye on it . My truck has a oil pressure gauge and it doesnt show the exact same pressure all the time
Old Nov 27, 2004 | 05:03 PM
DBZ33's Avatar
DBZ33
I had the Vortech installed on my 350z and the oil would be around 10-20 psi when warm. I thought it was kind of low also but it is fine. Good Luck.
bcoffee20
Nov 19, 2015 06:39 PM
Vigman
Nov 17, 2015 04:34 AM
kyin
Oct 15, 2015 05:54 AM
seagrasser
Oct 11, 2015 03:27 PM
Inspatatrac
Sep 8, 2015 02:12 PM
