Just installed Vortech SS-..Questions..
Old Dec 12, 2004 | 07:27 AM
bjornstad's Avatar
bjornstad
Default Just installed Vortech SS-..Questions..
I am a new member of this site, living in Norway. I hope some of you can answer my questions.
I have just installed a Vortech SS in my 04-350Z. Our firm has a Dynapack Dyno and i dynoed the car today. The SS did not produce more than 0.4 bar (5.9psi) on 6500 o/min, and the AFR was going from 9.6 to 10.8.
Has some of you experienced problem with low pressure?
The SS belt is thight, and the bypass valve does not leak(i think)
Can I get software for the timing module from Vortech?
Is R4 the software for the Vortech SS timing module?
Howard
Old Dec 12, 2004 | 12:42 PM
booger's Avatar
booger
Howard.....First...do you have after market headers ? No cats ?. An open exhaust system can make a big difference on how much boost you make
Second thing I would check is your belt . It needs to be tighter than most think
Third thing I would do is adjust your BOV . It comes from Vortech adjusted to close late .
Old Dec 12, 2004 | 01:39 PM
teh215's Avatar
teh215
Welcome. As booger said, the exhaust system really seems to impact the maximum boost the Vortech can make. What were the dyno numbers? If the power is down then it is possible that the belt is slipping. As far as the R4 software, you can purchase that from www.splitsec.com for about $20 USD. (That's what I paid). Once you have installed the software on a PC, do a search on this site for tuning info. (There's lots of it)
Old Dec 12, 2004 | 02:37 PM
bjornstad's Avatar
bjornstad
Thank you for your reply...and I mean SC, not SS as written earlier. I`m from Norway you know...an other language
My mods are Stillen cat back exhaust and a self modded cold air intake. I still run stock headers and catalysators. I tried to tension the belt, and it helped a bit on the pressure, but it does not rise above 6 psi at the top revs (6500).
When i dynoed my car i had 286 HP and 383 NM/281 lb-ft he wheels at our Dynapack. My car Dynoed 246 HP nad 313 NM/230 lb-ft at the wheels NA with Stillen cat back exhaust and Injen cold air intake.
Vortech says they dynoed their test car to 412 HP (at the engine i asume) but they does not tell if there are any mods like new headers and removed cats at their car.
The engine now runs AFR between 9.6-10.6, way too rich i mean, so the fuel has to be tuned better.
Old Dec 12, 2004 | 06:52 PM
S12 driver's Avatar
S12 driver
Depend on the altitude of Norway, you might have to get a smaller pulley to compensate for the thinner atmosphere. Get the R40 software from SplitSecond, and tune the car. Most people on the board get around 340-370 whp from the Vortech at stock boost.
Old Dec 12, 2004 | 07:18 PM
stevensuf's Avatar
stevensuf
ecu problems, euro model not the same as us
Old Dec 13, 2004 | 01:10 PM
bjornstad's Avatar
bjornstad
Now i have figured out the pressure problem. The oil drain hose under the SC had a bend, so the oil could not return to the engine. Then the oil made much resistance in the SC gearbox, and the gearbox got very hot. Now the performance is much better! I`ll have a new dyno test tomorrow!
Old Dec 13, 2004 | 05:01 PM
booger's Avatar
booger
good to hear you found the problem .
Old Dec 13, 2004 | 07:46 PM
baptist's Avatar
baptist
I have a euro spec car with the Vortech and it has not caused any problems with my ECU, car runs great. Havent dyno'd it yet, but it pulls real hard.
Old Dec 14, 2004 | 09:22 AM
bjornstad's Avatar
bjornstad
How much boost does the internals in a stock VQ35DE manage?
Can you use a smaller SC pulley on the vortech and a stock engine?
Now i have a Vortech SC, Stillen exhaust and a Injen cold air intake(rebuilt)...What is the next steps/mods for my engine?I am not going to tear my engine apart (yet).
And where do i buy the parts?
Anyone who knows where to buy the Veilside front lip for the 350Z?
Old Dec 15, 2004 | 12:04 PM
bjornstad's Avatar
bjornstad
Now i have dynoed my 350Z Vortech SC...
The result was 336 whp/304 wtq (415 wnm) @ 8 psi (0.55 bar).
Stock was 215 whp after 10 miles.
With Stillen exhaust and Injen intake it had 246 whp/230 wtq after 6000 miles...
Dyno was made on our Dynapack Chassis Dynamometer in 5.gear.
Old Dec 15, 2004 | 02:08 PM
teh215's Avatar
teh215
Before I'd buy a smaller pulley, I would get a plenum to even out the airflow to all cylinders. What gauges have you installed?
As far as boost, you should be OK with the Vortech so far. It doesn't really seem to be the boost that is causing the problems but more so the tuning.
Old Dec 15, 2004 | 02:23 PM
booger's Avatar
booger
I think a Dynapack dyno is a load base dyno....so your numbers are good . A Dynojet dyno should be about 10% higher . So you would be at 360whp .
350Z_Al
Oct 29, 2020 07:44 PM
Extreme Dimensions
Southern California
Sep 24, 2015 03:35 PM
