Built Motor-BREAK -IN period
Old Dec 19, 2004 | 08:00 AM
g356gear's Avatar
g356gear
Originally posted by 350zDCalb
my car was previously tuned to 8.5 lbs or so putting down approx 465 (corrected) rwhp...again, that equates to approx 380rwhp here at 5500ft altitude.
it was tuned to maintain an a/f ratio of 11.4-11.6 across the band (for the most part a pretty healthy tune) i was pulling 5 degrees of timing with the greddy ignition harness.
...so that was the current tune...wouldn't putting lower compression pistons thus changing the cylinder pressure, make the previous tune be pretty far off anyway???
i DO appreciate the feedback, believe me, i want to do this right the second time around(should of would of could of-donr forged internal from day one)
THANKS
If the compression is the only thing that has changed ( no cams, etc.) then the tune should be close. The lower compresion will give a richer and dirtier burn because the car will have been tuned a little richer anyhow to keep detonation down with the stock higher compression. The lower compression will just magnify the richness of the tune. Like Phunk said...if you add the AAM system at the same time then you are changing a fuel delivery variable that will change the fuel amount being put into the motor. So why do it right away?? Like you said...you have this amount of money in the car now....why take the chance and have to do the motor again.
Old Dec 19, 2004 | 08:07 AM
g356gear's Avatar
g356gear
the not staying in one piece comment...are you referring to even forged internals? has anyone blown on an engine rebuild?...or are you ONLY referring to all of the bolt on kits blowing up stck motors? i want to do things right...cheap is not an option at this point, my 30k car is now a 50k car!
You may have forged internals but a bad tune can kill rings too. A broken piston or rod means that an engine would have to come apart again...just like rings that did not properly seat from too much fuel during the break-in. I have seen friends with 500 mile motors that were running too much fuel from a bad tune and the rings were ruined because of too much fuel washing the cylinder bores of oil. They pull the motor apart because it is smoking on deceleration and under power and the ring edges are so sharp you could cut paper with them.
Old Dec 20, 2004 | 11:38 PM
ReavTek's Avatar
ReavTek
I am in the process of arrangin a mild engine build up: forged pistons, rods, valves and valve springs. If I use a "turbo compression" set on an NA motor to break it in before I get the twin turbo (APS) is that bad?
Old Dec 21, 2004 | 09:27 AM
g356gear's Avatar
g356gear
I don't think it would be an issue...I considered it myself. The only problem is that unless you are installing a supercharger or single turbo it is almost easier to have the motor out of the car to install a TT kit. Some say why do it twice??
Old Dec 21, 2004 | 04:10 PM
G3po's Avatar
G3po
Default build up
I currently have my LB in the shop with similarly discussed mods and intend to add the APS system. In order to keep my engine builder "honest" I have been considering this one-two approach, even though hours can be saved with the all in one build "big bang approach. Since the APS TT for G plumbing is not out til ~March and my LB will be done in Jan, I am still considering this two step approach.
Oh yeah if you are doing valve springs and rods , you prolley wnat to consder at leas ta mild CAM upgrade. I am using the JWT S1.
Old Dec 22, 2004 | 10:51 PM
going deep's Avatar
going deep
Gents, this has been a really good read. Todd and I are basically in the same boat with only a few weeks in between. In fact, we are even using the same shop, Greddy TT, and future set up as well. Here's my question, what about installing the AAM fuel return system and waiting to change out the injectors until after the break in period? I know that the AAM system will deliver fuel in a much better way than before, but would that cause you be rich enough to damage rings? how about, installing the AAM system and checking the tune? If all is well, then swap out the injectors after a couple of weeks?
Old Dec 23, 2004 | 06:01 AM
350zDCalb's Avatar
350zDCalb
builtZmotors
ernie:
i asked the same question on another thread..let's see if we get the same response!
Old Dec 23, 2004 | 06:21 AM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
With the new fuel system, you will likely be running a bit rich at the top of the RPM range. From idle to 4000rpm, I doubt you would tell the difference. You'll use the eManage to scale the larger 550cc injectors that we all bought, and can fine tune from there. I certainly would hire someone to tune your cars right away...once you decide on you will break it in.
Remember, that everyone will have a slightly different method of breaking in a motor. None of which is decidely better than the other. Just trust your machine shop, and the piston manufacturer, to guide you in the break-in process.
Old Dec 23, 2004 | 09:23 AM
SilverSellout's Avatar
SilverSellout
It looks like this issue has been covered pretty well, but I thought I would add a bit to help some people understand what is happening when you break in a new motor. This is a pretty controversial subject among tuners, and I've seen this subject cause some ridiculous arguments...
First off, let me say that my method of breaking in a motor includes running the car at WOT in top gear within MINUTES of getting it warmed up. If that scares you, read this.
http://www.mototuneusa.com/break_in_secrets.htm
Old Dec 23, 2004 | 02:07 PM
Sharif@Forged
Forged Performance
That well worn link (although I couldnt open it) has made the rounds of just about every motorcyle, car, and lawnmower racing website. It seem very authoritative..but it is still very controversial...and anything but conclusive. Too each his own....good luck!
Old Dec 23, 2004 | 09:32 PM
SilverSellout
I agree that it is controversial, and not conclusive, but I don't think anything on this subject will ever be conclusive. In the end all we can do is go by who or what we believe, and see what happens. His method has never caused me a problem, but the races that I have won after breaking in a motor like that could very easily be attributed to driving skill instead of the engine making more power due to the break in process...
Old Dec 24, 2004 | 05:41 AM
dansouliere's Avatar
dansouliere
This guy claims that the manufacturers are wrong because they say to baby a brand new engine. Some manufacturers already break the engine in for you but most of the time they give you instructions to break it in easily but the instructions are not for the engine-they're for the rest of the car.
On a new car you have not only a fresh engine but also a new clutch, flywheel, pressure plate, you also have new discs and brake pads etc. If you took his breakin method then you'd have a wonderfully broken in engine and a clutch that's only going to last 1/2 as long. Same deal with the brakes.
Old Apr 5, 2005 | 09:45 PM
350zDCalb's Avatar
350zDCalb
builtZmotors
i will revive another buried thread...since this should be my reality tomorrow!!! i'm not gonna sleep tonight...then again, i shouldn't get too excited until i am actually driving my car away! (supposed to take delivery of my car tomorrow and dyno on sat)
Old Apr 6, 2005 | 05:33 AM
Aquineas's Avatar
Aquineas
Alright now you know that we expect a review sometime today! Congrats, btw. It's been a long time coming for you... Like a kid on Christmas Eve.
Old Apr 6, 2005 | 08:27 AM
hurahn's Avatar
hurahn
Yeah, I know. Now I've got to get my **** built now....
Originally Posted by phunk
running an engine rich is just as bad as lean... rich washs the oil off your cylinder walls and wears at your rings and hone due to excessive friction from lack of cylinder wall lubrication.
Chris350z03
Oct 8, 2023 07:19 PM
35reilly
Sep 28, 2015 07:42 AM
