possible boost leak. PIC OF R4 SCREENSHOT
Old Dec 22, 2004 | 04:55 PM
  #41
backagain's Avatar
backagain
that is how cold/warm it is now. so the temp shouldn't have anything to do with it, here is an idea, while fixing my heater, i released pressure on a line in the engine bay, green cap that said EVAP on it, is it possible that i messed something up, maybe kinked a hose hooked up to this line by releasing all pressure ? it says max 1 psi on the cap. should i tap some air into this line and see what happens ? or is that a big no no. ? thanks
Old Dec 22, 2004 | 05:35 PM
  #42
gspot35's Avatar
gspot35
Not only is temp a factor but humidity. It's much less humid around my area lately. Less water in the air, the easier it is to compress.
Old Dec 22, 2004 | 08:51 PM
  #43
backagain's Avatar
backagain
anyone that can answer the EVAP cap issue ?
Old Dec 23, 2004 | 07:34 PM
  #44
dynamic6er's Avatar
dynamic6er
That should just be for your emmissions system. I really think your boost issue is the belt slipping. We had this same problem and many others have reported it also.
Old Dec 24, 2004 | 07:55 AM
  #45
screaminz's Avatar
screaminz
If it were me I would take it back to the whom-ever you had install it... Maybe they did a rush job on the install and missed something...
screaminz
Old Dec 24, 2004 | 08:07 AM
  #46
jpc350z's Avatar
jpc350z
The EVAP question might have an implication .
http://www.atlanticz.ca/zclub/techti...can/index.html
Old Dec 24, 2004 | 08:24 AM
  #47
dfw350z's Avatar
dfw350z
Have you checked your belt tightness yet?
Old Dec 24, 2004 | 11:19 AM
  #48
backagain's Avatar
backagain
belt looks tight, no way to tell really unless im actually going full boost, would there be signs of the belt slipping ? it dosn't look frayed or anything, ,
Old Dec 24, 2004 | 01:45 PM
  #49
RegalZ's Avatar
RegalZ
Agreed, there definately looks to be a connection relative to the upper RPM's which is where the problem seems to be.
Old Dec 24, 2004 | 06:41 PM
  #50
backagain's Avatar
backagain
doesn't say how to fix it, should i try to add pressure back to the EVAP line ?
Old Dec 25, 2004 | 11:24 AM
  #51
jpc350z's Avatar
jpc350z
Personally I would first check with a "qualified mechanic" before trying anything. The question for the mechanic is whether a release of EVAP pressure could result in the the cars performance..You dont want to introduce another potential problem trying to solve this one..
Old Dec 25, 2004 | 02:48 PM
  #52
screaminz's Avatar
screaminz
And when you get it fixed don't fool with anything else (stick with phones) .......
screaminz
Old Dec 25, 2004 | 03:58 PM
  #53
backagain's Avatar
backagain
screaminz
haha, thanks
Old Dec 30, 2004 | 05:36 AM
  #54
screaminz's Avatar
screaminz
Well did you get your **** fixed???
screaminz
Old Dec 30, 2004 | 05:03 PM
  #55
backagain's Avatar
backagain
still not fixed, been trying to get in touch with z1motorsports, im trying to setup a date so they can take a look at it, no luck yet, im trying to go on jan 7th, so i can be there for their dyno day, but im kind of afraid to take a long trip with it acting like this, now the wideband a/f gauge is going up to 17.x sometimes reading out all the way lean, when i get up to about 4k rpm and above, it doesn't go below 14.5 or so, something is def wrong here.
Old Dec 31, 2004 | 07:01 AM
  #56
jpc350z's Avatar
jpc350z
With those A/F #'s I would be very hesitant driving the car.
Old Dec 31, 2004 | 08:46 AM
  #57
King Tut's Avatar
King Tut
Have you gotten the car in the air yet to check the aux fuel pump and FMU? I'm telling you call me this weekend or come over so we can get the car in the air and check some voltages and vaccum lines.
Old Dec 31, 2004 | 02:08 PM
  #58
backagain's Avatar
backagain
i'll be over your way tomorrow around 2, let me know if i can come over eariler and we'll get to work on it
Old Jan 2, 2005 | 05:45 PM
  #59
screaminz's Avatar
screaminz
So whats the word on your Vortech SC? You should have stayed there while they did the install so you know they didn't just slap in together...
screaminz
Old Jan 2, 2005 | 08:21 PM
  #60
backagain's Avatar
backagain
whats up guyz, well, i think i may have just fixed my car , not too sure yet, just went for one drive and it didn't do the bogging down, am a proud new owner of a jack and jack stands from sears today that helped me get under my car and examine it for the first time, everything looked ok. i was told that i could adjust the bov by someone to make it a bit louder. so i unscrewed the bolt and used an alen wrench to unscrew the bolt a little. tightend back down the bolt and took it for a drive to listen how loud it was now. and i'll be damed if it didn't bog down. will give further updates when i get back from another drive.
