Any blown TT motors at "stock" boost?
Originally posted by gq_626
Give it some time....it's too new....with only a handful of installations.
Althou they did get a chance to improve on all the problems the Greddy kit had...
Originally posted by L.A. Roadster
So If I plan on running 'stock' boost with forged pistons/rods, should I still drop the compression?
Thanks
Thanks
After a few months you will want more power. Especially if you get beat racing sombody
I think 9.0:1cr or 9.5:1cr would be a good choice.
I dont think anyone has blown their engine running the stock boost. Those who have blown it or have done some engine damage, have done so with the boost higher than the stock level. I bent a rod while road tuning at 7.1psi.
gurgen is one who blew his engine on stock boost
fine...stockish boost...
But Gurgens blew in the sub 6psi range.
Even if you want 400whp, and planned on changing internals, I would still go lower CR. 10.3:1 is too high of a CR for F/I on this car, and if you are going to change the internals out, it would be wise to go low.
But Gurgens blew in the sub 6psi range.Even if you want 400whp, and planned on changing internals, I would still go lower CR. 10.3:1 is too high of a CR for F/I on this car, and if you are going to change the internals out, it would be wise to go low.
sharif:
how much timing should i pull and at what rpm range (or how do you think it is best?)
my setup:
9.0 : 1 compression
goal 550 actual rwhp (est 17-18 psi)
i may start with 450 rwhp first for a month or two
anyway, how many degrees, i've heard all the methods...gradually pulling timing, pulling timing per boost.... what do u think???
my setup:
9.0 : 1 compression
Well here is the problem. I blew mine and was running at what I thought was 5.6psi....but....while racing someone down the 91fwy, some how.....some way, the psi level spiked to 10psi and there went all my rings and teh #6 rod.
Bottom line ..... engine should be rebuilt/reinforced so that in case of this happening, it will not damage the car.....
thx
